Okay guys im new here and im sure the info im looking for is already on the site but i have no clue where to find it.
So to make a long story short i bought 2 mk4s one tdi (alh 5 speed) and one 1.8t auto.
Im in the process of swapping everything over to the 1.8t body the motor is in all wired up in the engine bay but i am haveing trouble getting it to crank with the key.
I swapped the igniton and the gauge cluster and i tried to wire in the clutch saftey switch but not sure if i did it correctly. So when it wouldnt crank or anything i did some more research and found out about everyone talking about wiring in the 109 realy but no one seems to actualy exsplain or show how to.
So i would really appreciate if someone could show me a diagram or something on how to wire in the 109 relay and the clutch saftey switch.
Also is there another things that need to be wiried up for the car to run??
Thanks guys i appreciate it!
