PickleRick
- Joined
- Nov 29, 2017
- Location
- Greenville sc
- TDI
- 05 GLS BHW sedan 5 speed conversion. BHW Carver SantaCruz in progress
So i got a cel today. Cleared it and hasn't come back in about 30 miles. Im assuming that since my temp gauge sticks at 190 at normal running temp like it usually does i can rule out a sticky thermostat. No under or over heating. For no egr the heat does well on cool spring mornings.
Is the reading i get from vcds or torque pro the ecu side of the coolant sensor or the gauge side? I want to know If i should be looking for a difference in temps
