yes it is Siemens Wen it go over 1.7bar it shakes en de boost go up and down the map sensor is 3bar no?Measure with a boost gauge, your vagcom only can show 2601mbar because your map sensor at this level is maxed out.
Your ecu is Siemens PPD, right?
it the same as seat leon siemensSorry I thinked that was the same as Seat Leon FR, 2.0TDI 170hp, what are ecu numbers of your modell?
Post some logs to have a look.
Can be, but is not the more commonThere are a lot of tuners that work with PPD siemens better then most with bosch , just find the right one
extrange... here I have one with 1,7 bar boost without troubles. Are your car ok?yes it is Siemens Wen it go over 1.7bar it shakes en de boost go up and down the map sensor is 3bar no?
2717, I know it.There are some limiters at 1.7bars if I recall correctly. 1717 I think...
right2717, I know it.
Yes, He can definitely scale 4 bar MAP sensor very well! And it works fine! He also has a very good service and helpful attitude! Thank You for that!Now I can scale 4 bar MAP sensor in PPD if someone needs it.
