gbrandt
Hi,
I have a code:
00522 - Engine Coolant Temperature Sensor (G62)
30-10 Open or Short to Plus - intermittent
I put in a new temp sensor and the code did not clear. (update: I attempted to clear with VCDS/VAG-COM)
I tested the pins on the connector and one line to the ECU goes to ground, is this expected or do I have a short in my harness?
Thanks.
Gregor
I have a code:
Thanks.
Gregor
