Rico567
Did the 40K DSG service on our '13 Passat today at 39,685, also the first service I have ever performed on this car, as all previous maintenance was included. Seemed like a good idea to start with the biggest job first, and then spread it out over several days.
I performed the drain / measure / fill procedure, as I saw no reason to do the VW bottom fill procedure. From start to finish- about 3 hours, but a good bit of that time was because I had never done the DSG service before, and certain steps (and not the ones I expected) proved to take more time.
Rather than do a video, I will post a link at the end that is the best I have seen, and very accurate, on how to do this procedure.
Following are some random timings I did on various steps in the process:
1. Put car on ramps = 5 minutes
2. Remove battery and tray (gives access to filter) = 23 minutes. This operation wins the "funky award," both taking out and putting back in.
3. Remove belly pan = 10 minutes off, same back on. This is a PITA, at least I feel this way, because in 50 years of driving and close to 20 vehicles I have never had one with a belly pan.
4. Drain #1 (fluid that emerges when big 14mm drain plug is removed) = 5 min. Got a little over a liter at this stage.
5. Drain #2 (fluid that emerges when 8mm snorkel is removed) = 15 min., basically let it quit dripping). Got around 3.5 liters.
6. Replaced snorkel and drain plug w/ new washer, refilled DSG (used amount drained + 200 ml for filter) with 4.7 liters. I put the 5 bottles of new oil in hot tap water in the kitchen sink before I started the whole process. This time was the biggest surprise = 5 min. / liter. I used the $8 "Hoppy Flo-Tool", available from Amazon, Wal-Mart, etc. The plastic fitting on the end of the hose of the Flo-Tool fits the opening in the filter housing perfectly— I mean as if it were made for it. I just hung the funnel part of the Flo-Tool from the hood with a wire, then I could just pour in a liter and go do something else, like replace the belly pan.
7. Installed new filter & O-ring = <5 min., secured cap.
8. Replaced battery tray and battery. Took longer than taking out, the winner for the most single time consuming operation of the whole day was trying to figure out how to reinstall the battery clamp (which I finally did, after maybe 15 minutes).
9. Put on engine cover and started car, ran through the gear selector as shown in video (10 seconds in each position / each way), then backed car off ramps and took for test drive. Drove fine.
There are a number of videos on how to do this DSG service, the following is my favorite:
https://www.youtube.com/watch?v=K4woqUj8qLY
My conclusion about the DSG service: a few people have made much of this, but it is very DIYable for the average owner, although maybe not as one's first rodeo. My experience only reinforces in my mind that what many people pay for this to be done is just absurd, if not highway robbery.
