Old May 26th, 2016, 02:15   #61
poxxxy
Old thread revival again, long time turbo conversion in the making . MK4 1.9 TDI ARL PD 150 with VNT 17 standard... now will be fitted with a hybrid turbo i've had built up for me. It has a Merc 2260VKLR CHRA and cold side on a BMW 2260VK exhaust housing (v-bands).
Now I need to figure out what oil line connections I need... at the moment the water/oil flange has been tapped and fitted with what looks to be a standard oil union for the oil inlet. On the oil return outlet we have a push fit connection screwed into the flange of around 1/2" outer diameter (ID of pipe will need to be 1/2"), water inlet has a 3/8 outer diameter push fit (ID of pipe will need to be 3/8").
I am unsure on what thread exactly is on the standard turbo union.
What size is the banjo on oil filter housing end?
Yesterday I picked up the push in water return pipe (that bolts onto the CHRA) from mercedes. I'm not yet sure how this will fit.
The oil return is also a little bit of a puzzle.
I need to try and get some hoses made up as they are the last piece of the puzzle in this turbo conversion project (apart from actually seeing if everything fits ok!).
If anyone can help me it would be greatly appreciated.
poxxxy is offline   Reply With Quote
Old May 26th, 2016, 07:57   #62
[486]
TDI(s): 02 golf ALH
12mm, coarse thread (I forget the pitch exactly, but it looks like 1.75 on the one sitting here)
ETA: shut up dummy past me, future me now knows it is m12x1.5
Old May 26th, 2016, 21:39   #63
Nevada_TDI
I will try to find the vendor, but I bought a Golf/Jetta flex line off ebay for $30.00 or so and it has the banjo on one end, and a 90 on the other end. It has been problem free for many miles. On my turbo there is a oil flow restricting "washer" that is between the oil fitting and the turbo body, and did not cause any troubles for the oil supply as my turbos have not had oiling issues. The factory got it right this time...
Old September 13th, 2016, 17:05   #64
raenglehart
Originally Posted by mrrhtuner View Post
I came across this thread.
http://www.ptaaron.com/oil-line/
Has anybody tried to make their own such as the link above?
I was looking into doing that as well, but after looking up all the parts, it came out to be almost $65 and that was via eBay.
I'm going to go after the one piece flex line as mentioned by several others throughout this thread and others. I'm running stock stuff, and no plans to make any big power upgrades any time soon. Factory line cracked at the turbo end connection on me about a week ago. I'll also replace the turbo union fitting as well since I have it out.
raenglehart is offline   Reply With Quote
Old February 20th, 2017, 17:44   #65
jhax
Bump again, will the noted turbo chra banjo bolt fit into a GTC1549VZ?
jhax is offline   Reply With Quote
Old March 26th, 2020, 11:28   #66
ClimbRunOm
Sorry to necro an old post, but I picked up a braided stainless (Teflon) hose +fittings from our local hydraulic shop, ($80! ) and I was thinking about making a little heat shield to insulate it slightly from the exhaust manifold...
I was thinking either wrapping the turbo side in some of that fiberglass exhaust tape ($5), OR making a little sheet metal heat shield (1hr)... (Or both)
Has anyone added any insulation to their flexible turbo oil feed line?
EDIT: did anyone use Teflon tape on the threads when installing the line?
EDIT2: This is for an ALH TDI
ClimbRunOm is offline   Reply With Quote
Old March 27th, 2020, 08:23   #67
jwrb
If you are going to put heat insulation on the line, use dedicated hose heat insulation. it's somewhat rubbery on the outside, OR make a little metal heat shield.
I've never found that it''s needed, but if you want to be cautious feel free.
The threads should not need ny teflon tape due to copper washers etc, however if you have a non-stock type of fitting, it may possibly be needed.
ARL Block, Machined BLT Pistons, AJM Crank, Pauter X Beam rods, Ported Head, Double Springs, Uprated Lifters, Colt Stage 3 Cam, 11mm IP w/ DE143, Mec Evo .330. Compound VNT setup.
Final assembly in progress.
jwrb is offline   Reply With Quote
Old March 29th, 2020, 18:57   #68
Rrusse11
https://www.ebay.com/itm/VW-TDI-1-9-....c100008.m2219
Hmmm, like this one? Shields et al aren't necessary IMO.
RC4: 11mm pump, 17/22, .230 nozzles, 3barMAP,EGR Delete, PD150Intake,SMIC,2.5" Exhaust: Koni Sp Reds, Wagon Springs, ~1"/2"lift:VR6 fr swaybar, Top strut & rear tie bar: 215/55ZR16 GMax AS05's, 10mm/20mm spacers, 35# @: skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: : VR6 fr, TT rr Brks: Catchcan
Rrusse11 is online now   Reply With Quote
Old March 30th, 2020, 03:42   #69
eddieleephd
Fuel Economy: 38mix / 47@70-75
I have the parts used listed somewhere on here. I might be able to find them. However, I replaced the banjo fitting with a straight threaded fitting.
Most I have seen dispatch with the banjo fitting.
Sent from my moto g(7) power using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, Bosio DLC 1019's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is online now   Reply With Quote
05 TDI Golf turbo replacement pics and oil feed line replaced w/ steel braided line. Kruso VW MKV-A5 Golf/Jettas 6 May 8th, 2013 20:52
WTB Braided steel Oil Feed Line for AHU i8therice Private TDI Items for Sale/Wanted 1 June 4th, 2012 05:07
WANTED: Stainless steel braided turbo oil feed line 2003 ARL engine. JakobDK Private TDI Items for Sale/Wanted 1 April 9th, 2012 14:35
Braided turbo oil feed line Bobby Singh Private TDI Items for Sale/Wanted 0 April 6th, 2010 13:29
What are your thoughts on steel braided oil feed line? b18onboost TDI 101 13 April 14th, 2008 10:17
Page generated in 0.15701 seconds with 13 queries
[Output: 98.27 Kb. compressed to 84.97 Kb. by saving 13.29 Kb. (13.53%)]
