I took delivery of a 2018 Chevy Volt on 8/11/18. This morning I received a diagnostic report from OnStar. Thought some may find it interesting:
ENERGY EFFICIENCY
Fuel Economy:
-- mpg
Electric Consumption:
33 kW-hr/100 miles
Electric Miles:
1,728
Gas Miles:
876
Total Miles:
2,604
Percentage on Electric:
66 %
Estimated Gallons of Fuel Saved:
-- gal
Estimated CO2 Avoided:
-- lbs
Data is based on total miles driven since last email report.
Get more detail
REQUIRED MAINTENANCE
Vehicle Maintenance
No oil change due at this time.
Remaining Oil Life: 92%
Mileage: 2,648
View maintenance summary
Learn about oil life
Tire Pressure: Low (Add Air)
One or more tires are low and need air. Inflate them to the recommended tire pressure listed below as soon as possible.
Properly inflated tires can improve your fuel economy, vehicle performance, and tire life.
Recommended tire pressure:
Front: 36psi | Rear: 36psi
Left Front:
Low,32psi
Left Rear:
Low,32psi
Right Front:
Low,33psi
Right Rear:
Low,33psi
Learn about tire pressure
Recalls and Programs
To check for recalls and programs on your GM vehicle, click here.
Odometer-Based Maintenance Items
Based on your current mileage, no items on the additional maintenance list are due at this time.
Warranty Tracker
Your warranty coverage is current and active.
Following up with some cost data and MPG data.
Gas used in 876 miles = 22.197 gal. MPG = 39.46479
Gas cost = $75.09 or $3.3839 per gallon (Hey, I live in California)
Gas cost per mile = $.0857
Electric miles = 1728
KW used for 1728 miles @ 33/100 miles = 570.4 KW
Cost under current EV rate plan for 1728 miles = $89.02
Cost per electric mile = $.05152
Average fuel cost for 2604 miles = ($89.02 + $75.09) = $164.11
Average total fuel cost/mile for 2604 = $.063
Not trying to "convert" anyone. Just my first batch of cost to operate. Thought some of you may find it interesting.
