davidm2232
Wow. Never knew that. Very good to know.yes, all the transmissions I listed above have the same bell housing to transmission bolt pattern
This isn't a MK4 tdi, its a big heavy Toyota. Can't say we didn't warn you,As far as clutches go, I would say Southbend is the name in performance clutches. We will be using the 5vzfe flywheel and clutch setup. Southbend claims 400 ft-lb and I know many TDIs with South bends that have zero clutch issues.
I can't imagine a stock 4runner clutch could hold 400 ft-lb. I guess we will see when everything goes together. I told southbend what I was building and they said their stage 2 endurance would be perfect.This isn't a MK4 tdi, its a big heavy Toyota. Can't say we didn't warn you,
this ^^ vehicle weight, tire size, tire rotational mass and gearing all have an effect on a clutches ability to hold... that being said i have heard good things about sb clutches in toyota conversionsThis isn't a MK4 tdi, its a big heavy Toyota. Can't say we didn't warn you,
wasn't disagreeing with your clutch choice, was just saying a clutch that holds "xxx ft lb" in a 3100 lb car with 24" tall tires will not hold up the same in a vehicle that weighs more with taller heavier tires .... i'm sure the SB clutch you have coming will hold up just fine .... please post photos when it arrives, im curious as to what parts they used as a base for the upgrade
Seems to me that to a clutch torque is just torque, whether it's developed in getting a light car to accelerate, or a heavier car with less acceleration. I certainly grant that it is easier to develop the torque in the truck.wasn't disagreeing with your clutch choice, was just saying a clutch that holds "xxx ft lb" in a 3100 lb car with 24" tall tires will not hold up the same in a vehicle that weighs more with taller heavier tires .... i'm sure the SB clutch you have coming will hold up just fine .... please post photos when it arrives, im curious as to what parts they used as a base for the upgrade
Torque isn't torque, because of the way its produced, lol. A diesel produces it very low in the rpm range, so for a gas engine is designed to hold it at a higher rpm. That's why for example, a Centerforce clutch is useless in turbo applications.Seems to me that to a clutch torque is just torque, whether it's developed in getting a light car to accelerate, or a heavier car with less acceleration. I certainly grant that it is easier to develop the torque in the truck.
Centerforce is different. Most clutches do not change clamping force with RPM.Torque isn't torque, because of the way its produced, lol. A diesel produces it very low in the rpm range, so for a gas engine is designed to hold it at a higher rpm. That's why for example, a Centerforce clutch is useless in turbo applications.
So a clutch designed to hold a 400 ft/lb V6 isn't the same as a clutch designed for a 400 ft/lb diesel.
Did you actually read what I wrote?Centerforce is different. Most clutches do not change clamping force with RPM.
I quoted it didn't I? I have a Centerforce, you do know how they work, right?Did you actually read what I wrote?
I know Centerforce is different, hence why I said it. They work great, I have a few customers using them but NOT in turbo vehicles. They do seem to work ok in Diesel trucks, IE Ford, Cummins etc.I quoted it didn't I? I have a Centerforce, you do know how they work, right?
I recently pulled and swapped two 3VZ-Es without too much difficulty. I yanked the 3.0/automatic out of my T100 donor truck (separated on the ground), pulled the blown engine out of my 4wd five speed truck, then swapped the good engine in. Just realized, I had deleted my crossover pipe before all this, so the top bellhousing bolts were purdy easy. Also, I had the front core support and left inner fender removed. (minor details....)it's tough pulling the v6, did a motor change a few years back on a 90' runner ... manual says to pull the engine and trans together and split on them outside the truck but i chose the hard way as well .... as for the cruise stalk not sure you can get the toy stalk working with the vw ecm easily ... i used a cut down vw cruise stalk attached to the toy column
yeah that crossover pipe adds much difficulty to the procedure... i was able to get at the six nuts and move it out of the way for top bell bolt access but it was a knuckle scraper for sureGreat thread! It's good to get a more complete explanation of what I've been trying to figure out anyhow.
Trying to wrap my head around the above tool?
there are no dowel pins for alignment with the acme plate ... it is a fatal flaw which must be addressed or you will have clutch wear, vibration, input shaft bearing wear, pilot bearing wear or any/all the above... http://forums.tdiclub.com/showthread.php?t=429695... my advice for the most accurate centering is to pick up or borrow a small dial indicator, rig it solidly to the crank, buy an assortment of metric dowel pins at your local industrial supply ... center the bell using the dial indicator method and backweld the dowels to the adapter plate through the rear .... good luck!I'm kind of confused. Opened up the adapter plate yesterday and there are dowel pins for the Toyota transmission. Is this a change in design or are we talking about the dowel pins on the TDI block? Instructions with the kit said to remove those. It bolts up pretty snugly to the block so I don't think there is too much room for adjustment. In any case, got the TDI mocked up in the 4runner engine bay. It fits pretty good. Did need to trim the driver's side mount to clear the A/C compressor and massage the firewall to fit the vacuum pump. Having issues with the steering stabilizer though. Engine needs to go down another couple inches but is sitting right on the stabilizer. Any ideas? ECU, gas pedal, and OBD connector are hooked up. I was able to turn the key on and pull codes so that is awesome. Pics to follow.
EDIT:....so now I see dowel pins for the trans side of the adapter plate...maybe he just started adding these? ....I would still check the accuracy of alignment as I saw some difference between blocks when the adapter was swapped between them .... could you post some closer pictures of the alignment dowels?...they look to be pass through where toyota uses solid doweling for engine to trans alignment
