S
SIUMATTHEW
Guest
Just a couple questions after my tb install last night which was a lot more rough then i thought those gates belts are snug ! and yes the cam was fully counterclockwise and the tensioner was set properly
here are the few questions which you all will know off the top of your heads.
The tensioner tab is a little further then where its suppose to be by about 3/16 does it matter? Didn't seem to move much more tension anyway i reset it to where its suppose to be but when i torque it down and spin the engine over it moves over a little bit...
The cam bolts are not in the same spot as they were with the old belt. It is in time as i spun it over about 3 full revolutions installing the locks they go in with only about 1/16th wiggle needed to set both of them.
The belt is not center on the crank or the water pump but i figured that it will slide to where it comfortable when i fire her up.
sorry for the multiple posts no one was reading the other one and i need trhese answers before i put this thing back together! Thanks guys!!!
