Been having a problem with starting one of my Passats 1st thing in the AM or after the car's been sitting for many hours. It starts but smokes a lot and runs on what seems to be 3 cylinders but pretty quickly comes up to 4 cylinders with a little throttle application. The colder it is outside, the worse the car smokes and longer it runs on 3. My initial thought would have been glow plugs but the car does it even when its warmer outside, like maybe 50-60F. BTW, the smoke it mostly white with a slight blue tint. I will also get smoke when the car has just been started and is decending a hill and with slight throttle application. It also seems to hesitate a bit in this situation.
Does this sound like tired injectors? Is there something else I should check? FYI, the car runs great when its outside of the 1st maybe 2 minutes of running. Its got lots of power, in fact, more power than our Upsolute chipped Passat. Its got 190k miles and I have no idea if the injectors have ever been changed.
