Turboed
Hello,
I really am stumped with this problem. I have a 2000 jetta tdi that starts and runs fine for 2 seconds then dies every time. I have a flashing glow plug light that comes on and I have engine light on. The immobilizer light is not on. I cannot get the engine controller to respond with my vag com but have never had a problem doing so before. I have checked the dlc power, ground and k-link voltage(9v). I have checked and changed the obvious fuel filter and have fuel coming out of the lines. The fuel shut off has power all the time the ignition is on. Checked all the fuses. Tested the 109 relay. The relay is fine but the input ground #85 when checked with my power probe 3 displayed sporatic ground on and off and blinks fast. I am not sure if this is normal or not and may be coming from the ECM. I am pulling my hair out as this is my family car. I am a mechanic but I need some one that knows where to go from here. Any help is very very much appreciated.
Thank you,
Russ
Thank you,
Russ
