So my 00' Tdi beetle's water pump had recently started leaking. I've owned the beetle since late last year, the previous owner didn't know if or when the timing belt had been changed, (car now has 207k on it) non of which I was very concerned with given the sale price was a whooping $1100 bucks.
Anyway, I inspected the belt and found it in "ok for now" shape with plans to do the job myself this summer.
Fast forward to recent.
I ordered up all the parts, 62mm lower, tensioner, metal blade water pump, belt, and the other rollers as well, all 100k part numbers.
I've done timing belts in other cars a few times, however this was my first diesel.
Before the parts arrived I got the car apart and as far as I could go without the new parts. Crank at tdc, cam also. I don't own the "right tools" so with the cam I used a steel bar that fit in the slot perfectly, I locked the injector pump simply with a bolt that fit the hole perfectly.
So I've read the "right way" how to. Which was a great deal of help to a diesel newb like myself.
But what confused me, was why exactly the cam gear needed to come off, and why the injector pump needed to be loosened and reset with vag-com.
Many hours of searching and reading resulted in nothing more then "you have to" or, you "CANNOT" do this engine using the "mark and pray".
So I basicly said, "why not??"
The engine is locked, it ran perfect when I backed it into my garage, why wouldn't it run perfect again after the mark and match method?
I had perfect luck with my 02' 2.0 gasser (30k miles ago, still runs great)
So why can't I?
So last wendsday the parts arrived, and I did just that, mark and match at the crank, cam and injector pump. I didn't loosen the injector pump bolts, I didn't remove the cam gear.
And after it was all said and done, the engine still runs perfect.. no cell's, nothing different.
So,, with all that said. Am I missing something here?
Just wanted to share.
Oh and to any newbs like myself, the job wasn't difficult really.
So why can't I?
