Hello, new member here. I have a 2006 Jetta TDI with DSG transmission , it shifts perfectly until it gets hot and then flashes PRNDS , downshifts into 1st and goes to limp mode . I`ve checked for any obvious wiring issues along the harness and checked the transmission oil level and condition and did an autoscan
That Pressure Control Solenoid 2 which I think is the N216 Solenoid seems to be the problem.. My First question is do i go ahead and swap it out or are there other things to rule out first ? Secondly is how to positively identify the N216 . Is it marked N216 ?
Code:
Tuesday,23,April,2019,15:05:37:24985
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 18.9.1.0 HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: 3VWST71K66M770330 License Plate: HSO-70A
Mileage: 177650km-110386mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST71K66M770330 Mileage: 177650km-110386miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0F3300364
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 6491ADDEE25DA6B71A5-8030
No fault code found.
Readiness: 0 0 0 0 0 aaaaaaa
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000512021153
Coding: 0000020
VCID: 51FF740A8DEF231F413-8004
1 Fault Found:
17160 - Pressure Control Solenoid 2
P0776 - 012 - Open or Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101100
Fault Priority: 0
Fault Frequency: 255
Reset counter: 40
Mileage: 177596 km
Time Indication: 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3FDB42B22B7BA56FA77-806A
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DQ
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 76B5E79644C12427B41-8022
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000261194
Coding: 10018E234004180000140000001400000008730B5C
Shop #: WSC 91406 999 54009
VCID: 2A0D03E6C0F930C7E09-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 91406
1 Fault Found:
00987 - Lamp for Brake Light; Left (M9)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 64
Mileage: 174553 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.00 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 3C AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD03Z6EB
Coding: 0013123
VCID: 392F2CAA355F8B5F993-806C
Subsystem 1 - Serial number: 6332MSME0D454C7CS
Subsystem 2 - Serial number: 6342MSME0D3E440CM
Subsystem 3 - Serial number: 6351HSME091E1203/
Subsystem 4 - Serial number: 6361HSME091D0042/
Subsystem 5 - Serial number: 63727SME0863597CA
Subsystem 6 - Serial number: 63827SME0906423A
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0010021
VCID: 78A9E9AE4ED55257A6D-802C
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 852 P
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023303
Shop #: WSC 91489 999 103842
VCID: 3635279604416427741-8062
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105C128E6B
Coding: 3F3F0B40071002
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 64
Mileage: 177619 km
Time Indication: 0
Date: 2000.00.00
Time: 05:15:47
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 33331E821733710F53F-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 137803281B09058F880F048051A0
VCID: 74B1DD9E52BD36378A5-8020
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
011 - Open Circuit
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 372B2A92034B9D2F6F7-8062
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 A HW: 1K0 035 161 A
Component: Radio DE2 012 0015
Revision: 00012000 Serial number: VWZ4Z7F6113379
Coding: 0040400
VCID: 1D67D83A81B7D77F95B-8048
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 313F148AED2F431F213-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 323D1B86E8297807589-8066
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D0708FAF11727FF05B-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----(Elapsed Time: 01:45, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
