Here's my short story: my 2004 tdi wagon started getting louder the other day – thinking I had a problem with my exhaust I continued to drive the car over the weekend. On the fourth I hit a pot hole on the way up a dirt road. The car got very loud and vibrating, I put it in neutral and opened the hood after which it stalled out within a second. Looking at the engine I noticed a tilt and then the lightbulb went off in my head and the blood left my face. I broke an engine mount (thus the vibration and noise) on the passenger side. The engine leaned over and forced the engine mount bracket into the timing belt cover….the car stopped.
Already $150 out now thanks to a tow to a garage that doesn’t have the capacity to work on my TDI (I am in rural Washington up in the North Cascades). Found someone local with a VAG-com and willingness to work on the car. It could be a simple motor mount fix or it could be a tragic end to the internal health of my engine.
MY QUESTIONS: What diagnosis procedure should the mechanic use to determine whether the breaking of the mount and tilting of the engine into the timing belt did any damage to the internal workings of my car?
Once the engine is hoisted and verifying the timing belt looks okay should it be started or does the head need to come off in order to look for internal damage? what/how would internal damage be determined?
Thanks for the help!
