So having noticed my fuel economy steadily decline over the past year or two with no real explanation, I finally decided to take a half hour to check my camshaft at 144k miles. Sure enough, even though the engine sounds just fine all the exhaust valve lobes are worn well past the chamfered edge.
I decided to get a colt cam from kermatdi, if just for the 300k warranty. Does anybody know if it's worth it to get the stage 3 over the stage 2, and are there any potential down sides I should be aware of? i.e. potential early wear of other components, etc.
Also, I see VW# T10051 recommended for removing the camshaft pulley. Since I already have one laying around, does anybody know if the metalnerd counterhold used for the timing belt change, Part MN3036, will work for this? I'm sure I can bodge something together to avoid buying the tool, but I just thought I'd ask
Thanks!
Thanks!
