I have Jetta TDI 2005. My fan is working on first 3 lower speeds , but on the 4th speed works around 30-45 sec then stops. When I turn OFF motor for about 1 min motor works normally on first 3 speeds , but there is still the same issue with the 4th speed.
I've replaced the resistor but the problem is still there. Is there any way to test the motor blower to be sure that that is the problem? Could it maybe be a relay?
