Jazer3
I bought an 06 TDI Jetta and the guy ran it with almost no oil until a piston shattered and a valve snapped, the head is garbage but the bottom end is still good. it already has a stage 1 tune I just want to build a durable medium power fuel efficient engine that I can upgrade more later, it needs to pass smog here in California. The block will need at least bored .30 probably .60 over so I was thinking of making it a 2.0 TDI by boring .90 over and using bhw pistons since no matter what I will need new pistons. I'm thinking of using a used bew head so I get the better injectors and lower compression ratio so I can run higher boost and run less risk of cracking the head with the extended injection cycle of the current tune and any tune I get in the future. I live in an extremely warm climate so hard starts won't be a problem. All the research I've done says this will go together easily. I'm assuming the valve cover, intake, and exhaust will mount to this new head the same I may port the divided intake runners. Does anyone know of anything I'm missing that's going to stop me in my tracks after I get started?
