Luddite1811
So I've read several posts and am new to modifying cars but not to actually doing mechanical work and would like some feedback on my issue and upgrades. Sorry for the long post...
I'm a vcds amateur...so a little back story...I have a 2012 golf tdi/dsg with ~148k miles and the engine/emission management light was going on and off periodically over the course of a few months and then has remained solid for a month or so now. I've noticed a decent drop in fuel economy so I decided to buy a vag-com to finally check on it...I got the faults below, before I cleared the code and then it came back on a few hours later after driving a few times and having the engine off/on for those trips...
so one initial question is since it came back and from the data prior to clearing the code does it look like I just have a bad egr filter or a bad egr filter and dpf or maybe just a bad/cracked dpf? The dpf warning lamp has never come on.
The next questions I have is I'm looking at getting the cr170 turbo along with the downpipe and full exhaust and resonator, as well as the ecu tune and dsg tune, is there anything else I would need for example if got rid of the egr cooler as I've read some people leave that on for some reason?
Will the cr170 turbo upgrade work with the stage 2 tune or only stage 3?
Anything else required besides the above list with a stage 3?
Can I remove the Dpf/egg and install the downpipe and run it safely besides the CEL coming on while saving up for the tune and turbo?
Any downside of going stage 2 vs 3?
Buzzken vs Rawtek?
Neuro tune vs Malone?
I may have more questions just want to make sure I get everything prior to removing all of the parts.
BEFORE CLEARING CODE:
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 HG HW: 03L 907 309 AA
Component: R4 2,0L EDC G000AG 8178
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 01357 011 00200
VCID: 77A8E12663C7F13F1C3-8022
4 Faults Found:
001025 - EGR System
P0401 - 001 - Insufficient Flow - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 2
Fault Frequency: 255
Reset counter: 255
Mileage: 212870 km
Time Indication: 0
Date: 2016.04.29
Time: 11:48:29
Freeze Frame:
RPM: 1472 /min
Speed: 32.0 km/h
Voltage: 13.68 V
Load: 50.2 %
Load: 100.0 %
Mass Air / Rev.: 240.0 mg/str
Mass Air / Rev.: 330.0 mg/str
009231 - Exhaust Gas Recirculation System
P240F - 000 - Response too Slow - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 221485 km
Time Indication: 0
Date: 2016.06.07
Time: 08:14:20
Freeze Frame:
RPM: 1426 /min
Speed: 17.0 km/h
Load: 81.6 %
Mass Air / Rev.: 0.0 mg/str
Mass Air / Rev.: 35.0 mg/str
Mass Air / Rev.: 410.0 mg/str
Mass Air / Rev.: 500.0 mg/str
001025 - EGR System
P0401 - 002 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 238159 km
Time Indication: 0
Date: 2017.02.06
Time: 15:35:04
Freeze Frame:
RPM: 1725 /min
Speed: 72.0 km/h
Voltage: 14.21 V
Load: 95.7 %
Load: 100.0 %
Mass Air / Rev.: 540.0 mg/str
Mass Air / Rev.: 645.0 mg/str
008194 - Particulate Trap Bank 1
P2002 - 002 - Efficiency Below Threshold - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 238954 km
Time Indication: 0
Date: 2017.02.13
Time: 14:34:15
Freeze Frame:
RPM: 2576 /min
Speed: 130.0 km/h
Pressure: 59 mbar
Hex Value: 0xFF01
Temperature: 462.0�C
(no units): 408.0
Mileage: 200 km
Readiness: 1 3 0 0 0
AFTER CLEARING CODE:
Coding: 0050078
1 Fault Found:
001025 - EGR System
P0401 - 001 - Insufficient Flow - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 239137 km
Time Indication: 0
Date: 2017.02.15
Time: 13:52:39
Freeze Frame:
RPM: 1863 /min
Speed: 94.0 km/h
Voltage: 14.21 V
Load: 82.0 %
Load: 100.0 %
Mass Air / Rev.: 380.0 mg/str
Mass Air / Rev.: 530.0 mg/str
Readiness: 1 1 0 0 0
Buzzken vs Rawtek?
Coding: 0050078
4 Faults Found:
001025 - EGR System
Freeze Frame:
Fault Priority: 2
Reset counter: 255
Mileage: 212870 km
Time Indication: 0
Date: 2016.04.29
Time: 11:48:29
Freeze Frame:
RPM: 1472 /min
Speed: 32.0 km/h
Voltage: 13.68 V
Load: 50.2 %
Load: 100.0 %
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 221485 km
Time Indication: 0
Date: 2016.06.07
Time: 08:14:20
Freeze Frame:
RPM: 1426 /min
Speed: 17.0 km/h
Load: 81.6 %
001025 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 238159 km
Time Indication: 0
Date: 2017.02.06
Time: 15:35:04
Freeze Frame:
RPM: 1725 /min
Speed: 72.0 km/h
Voltage: 14.21 V
Load: 95.7 %
Load: 100.0 %
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 238954 km
Time Indication: 0
Date: 2017.02.13
Time: 14:34:15
Freeze Frame:
RPM: 2576 /min
Speed: 130.0 km/h
Pressure: 59 mbar
Hex Value: 0xFF01
(no units): 408.0
Mileage: 200 km
Coding: 0050078
1 Fault Found:
001025 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 239137 km
Time Indication: 0
Date: 2017.02.15
Time: 13:52:39
Freeze Frame:
RPM: 1863 /min
Speed: 94.0 km/h
Voltage: 14.21 V
Load: 82.0 %
Load: 100.0 %
