Old September 29th, 2018, 10:35   #1
Jakub
Default DSG PRDS flashing only into reverse
So Iíve read this is a very common problem but i would like to ask if anyone can narrow it down as to where I should start looking
Itís a 06 jetta tdi Brm engine
Had a tranny leak and I fixed that
What happens is if Iím driving and I stop and put it in reverse the car wonít engage but tries to, you can hear the clicking. Sometimes it goes into reverse, othertimes starts flashing.
When this happens if I turn off the car and turn it back on it will engage into reverse and then I can put it in drive again.
Also if I start the car and put it into reverse before I put it into drive it backs up fine.
Is it a bad mechatronic or something else ?
Jakub is offline   Reply With Quote
Old September 29th, 2018, 18:44   #2
jonferns
jonferns's Avatar
TDI(s): '15 Golf
What are the details of the leak, and the repair? Correct fluid level set after repair, with the correct fluid? DSG service performed every 40k? What faults does VCDS show?
'15 Golf S TDI - 68k, DSG
'12 JSW TDI - 99k, 6MT Buyback complete!
'06 Jetta TDI - 150k, DSG, Package 2, Malone Stage 1, RCD510 Retrofit
'06 Jetta TDI - 220k, DSG
jonferns is offline   Reply With Quote
Old September 29th, 2018, 23:31   #3
Jakub
The leak was caused by a broken cv axle that broke the tranny case but I had that repaired, I used dealership gear oil and theoretically filled it correctly. The code I’ll check in the morning
Old September 30th, 2018, 12:00   #4
Jakub
Vagcom code is 19143 unexpected/implausible mechanical gear disengagement P2711-004- intermittent
Old October 1st, 2018, 11:47   #5
RV9Factory
TDI(s): 2006 Jetta
When I had DSG issues and flashing PRNDS, it ended up being a ground that I didn't tighten down after some work I did.
RV9Factory is offline   Reply With Quote
Old October 2nd, 2018, 21:16   #6
Jakub
Grounds as in the ones that go from Tranny to frame ?
Old October 3rd, 2018, 16:26   #7
Mattyoctavia
The clutches are worn out and need to be replaced. I had this problem with my dsg also. The clutches weren’t clearing properly
Mattyoctavia is offline   Reply With Quote
Old October 4th, 2018, 07:06   #8
tdiatlast
How many miles on the trans?
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2017 Ford Energi Titanium, purchased 12/15/18
tdiatlast is online now   Reply With Quote
Old October 9th, 2018, 15:07   #9
Jakub
The car has 196,000 miles
If I’m on an uphill facing up and throw it in reverse the car will go in reverse no problem. If I have the car on flat ground and throw it in reverse from drive it won’t shift, just making noise as if trying to shift. Sometimes it does engage in to reverse after atempiting.
The only way I get to put it in reverse us, turn off engine and restart the car then go to reverse first.
Still think it’s clutch’s or metatromics ?
Old October 9th, 2018, 15:07   #10
Jakub
Where and which ground was bad ?
Old October 14th, 2018, 02:00   #11
Mattyoctavia
Have you changed the clutch pack yet?
Old October 14th, 2018, 18:07   #12
Jakub
Never changed the clutch pack is t hard? Why would the clutch’s be bad if it sounds like it has trouble disengaging ?
Old October 16th, 2018, 22:15   #13
Jakub
Does anyone know the transmission codes if I decide to buy a used one ?
Old October 18th, 2018, 09:25   #14
Jakub
And are the gas and diesel DSG’s the same or the gearing different ?
Old October 18th, 2018, 10:47   #15
oilhammer's Avatar
Fuel Economy: fantastic
You need to use one from a BRM car, nothing else will work.
There are two different 3-digit trans codes for BRMs. So long as you get the whole thing, you can use either one. The M-units are not interchangeable, so you have to make sure of that if the time ever comes to replace that.
The trans code will be one your build tag in the trunk, or you can ask the dealer to get it from your VIN. Otherwise, you'll have to look under the mount bracket on the trans (the one underneath the battery tray) as that is where they put it on the 02E DSG, unfortunately.
ETKA lists three, but I have only ever seen two different codes. I do not remember which one I have never seen. But the ones listed are HQN, HXU, and JPL. I *think* the JPL is the one I have never seen.
www.cardocautomotive.com
DSG in reverse nate68178 VW Passat Family (NMS and B7) TDIs (2012+) 26 June 15th, 2018 22:53
Flashing R and no Reverse! Yikes! InfoSec Guy VW Passat Family (NMS and B7) TDIs (2012+) 44 January 1st, 2016 14:20
DSG observations while in Reverse skinnyb TDI 101 0 May 26th, 2013 10:40
Reverse uphill with the DSG... Kimo VW Passat Family (NMS and B7) TDIs (2012+) 3 December 24th, 2011 12:41
Reverse gear (DSG) jaberoo VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 2 June 17th, 2010 23:51
Page generated in 0.17215 seconds with 13 queries
[Output: 118.24 Kb. compressed to 98.06 Kb. by saving 20.18 Kb. (17.07%)]
