Block Heater and Battery Blanket
Jjakimiak
Montanyuh
03 GLS Sedan,
Who has a recommended block heater and battery blanket set up?
Is there an advantage to including a oil pan heater in mix?
I'm pretty much up in Canada these days and at 5K Ft elevation......
John
02 Jetta TDI
jettawreck
Northern Minnesota-55744
2001 Jetta and 2003 Jetta
There is no "block heater" available as there are no typical frost plugs to install one. Coolant heaters such as FrostHeater using a ZeroStart heating unit work great. Oil pan heater with a proper coolant heater install is not needed as the warm coolant circulates thru the oil cooler and oil delivered to the vitals is warmed. It will start just like summer time and depending on how long it's plugged in can it have some noticeable cabin heat upon start up.
Do a search, it's common stuff.
scooperhsd
Kansas City KS
NB, 2000, RED(5 Speed conversion) 2015 Golf SE
Technically, with proper oil (5wX / 0wX speced for your car), proper local winterized fuel (perhaps treated with an antigel product such as PowerService White), and a good battery, and a good set of working glowplugs - neither a battery blanket nor a frostheater should be necessary. They can't hurt, however.
Abacus
That helpful B4 guy
Only the B4V left
They make a WORLD of difference. I've started mine unaided at -35°F before but it wasn't happy. Years later, with everything plugged in, it started at -25° F like it was a 40° day.
phaser
Oregon
2004 Jetta PD - 490k
Battery blanket not really necessary as the FrostHeater mounts right under the battery, warming it as well as the engine.
red16vdub
(617) City of CHAMPIONS
03 JSW 5spd
This ^^
Bajan
jettawreck
Over 10 years with my ZeroStart unit and no issues.
Perhaps if everything is "perfect" the ALH will indeed start in -30F but for the most part, few cars being used by the majority have everything perfect ALL the time and a poor time to find that out is after the fact.
Driving off after a pre-warmed engine is a totally different experience than a really cold one and it's certain that many have never experienced a -30F (and colder) weather much less such a cold start.
I've plugged mine in relatively few times, but being able to and not ever worrying about being able to get started effortlessly is a comforting haughty in severe cold.
I see a lot of questions and comments from many that live in places where it never/seldom gets actually cold enough to worry about it, so for those it's a "comfort" factor or a "damage control" (real or imagined-you choose/debate) effort for the vehicle's sake.
But, starting is just getting going. If the fuel isn't good and/or properly treated you aren't going far. If maintainence isn't kept up it will rear its ugly head somewhere unfortunate when you least want it. A lot of those places I travel are relatively remote and void of help or cell signal. Plan accordingly.
