dont forget stock weight flywheel is not the same thing as your thinking. Yes you wll have flywheels that will weigh the same but your Pressure plate will weigh more. if you go with a 22lbs flywheel you will actually be adding a couple of pounds to the rotating mass. my 14lbs fly and pressure plate weighed about the same as the stock set up as the stock Pressure plate is really light.
