Old August 11th, 2012, 23:53   #16
afterthisnap
I did mine today. It would have been a pretty easy job if my balljoint bolts didn't shear off
The OEM boots looked OK with 216k miles on them, but as I removed them it was pretty clear that they were not long for this world as the rubber was relatively easy to tear and not that supple.
I ditched the included OEM grease and tried Green Grease.
Hokey marketing, but the reviews are good.
The factory grease inside the inner boot looked pretty good, but the oil was separating from the thickener. The green grease stuff won't separate and is much much stickier than the black stuff- since the CV bearings don't really spin (like a wheel bearing) I figured the sticker stuff would hold on the loaded surfaces better.
The cost of the boots was more than a lifetime autozone CV (I've never had problems with them before), but I figured the non-damaged OEM units will last forever as long as the boots are doing their job.
afterthisnap is offline   Reply With Quote
Old November 28th, 2012, 19:37   #17
B100
B100's Avatar
TDI(s): 2003 Golf
I used to clean and repack the CV joints on my '71 Bus every 50k miles or so... how often should the joints on our TDIs be serviced?
2003 Golf 5-spd with ESP, DLC 1019 injectors, Koni Sports, CAT fuel filter, Panzer Plate, DieselGeek's bypass oil filter kit, Stage 4 Malone tune, South Bend SMF clutch, BV39 Turbo...
B100 is offline   Reply With Quote
Old November 29th, 2012, 19:17   #18
Bailout
Fuel Economy: Best 57.3 - highway.
So did you rebuild them yet?
I just did mine... FYI, check your bearings/hubs when you remove them... I ended up replacing bearings/hubs, tie rod ends (cause they were very worn), and ball joints because I had it all apart anyway... Didn't know I needed to do all that til I got the axles out. CV joints were very easy to rebuild - got my kits from idparts.
It's messy - so have some extra cardboard and plastic sheets around. I agree with thd YouTube vids... Not nearly as cosmic as one thinks.
iPhone Forum Junkie
Bailout is offline   Reply With Quote
Is there a CV Joint replacement "HOW TO? STRANGETDI TDI 101 29 July 30th, 2011 06:08
Inner CV joint replacement 2-Stroke Freak TDI 101 10 March 17th, 2010 19:08
CV Joint Replacement ttzuke44 TDI 101 4 July 30th, 2008 09:33
CV joint replacement? wakeboarder_shawn VW MKIV-A4 TDIs (VE and PD) 6 June 16th, 2006 13:55
What is involved with a CV Joint Replacement? STRANGETDI VW MKIV-A4 TDIs (VE and PD) 4 April 30th, 2005 14:35
Page generated in 0.11269 seconds with 11 queries
[Output: 59.60 Kb. compressed to 54.30 Kb. by saving 5.31 Kb. (8.90%)]
