Old March 13th, 2010, 16:20   #1
2-Stroke Freak
Default Inner CV joint replacement
I need to replace my inner CV joints on my 03 Wagon. Is there a how to thread that somone can link me to??
Thanks!
2-Stroke Freak is offline   Reply With Quote
Old March 13th, 2010, 20:31   #2
Canadian_Grizzly
Canadian_Grizzly's Avatar
TDI(s): 02 Jetta TDI
I don't know of a how-to but I did mine. I got the inners from Germanautoparts.com Do NOT replace with rebuilt or cheap replacements.
This link has some advice... http://forums.tdiclub.com/showthread...light=Inner+CV
Byron
Driver Found!
"There is lots of work to be done, if we are to achieve the kind of society people have the right to expect." Tommy Douglas
Having trouble with limp mode... Troubleshooting Low Power
Having trouble searching? Read this thread on advance search in forum http://forums.tdiclub.com/showthread.php?t=133579
Canadian_Grizzly is offline   Reply With Quote
Old March 14th, 2010, 20:18   #3
2-Stroke Freak
thanks for the link Grizz. I replaced them today. The most dificult part was getting the boots over the splines, and that wasn't allbad.
Old March 14th, 2010, 21:32   #4
Canadian_Grizzly
Cheers...
Byron
Driver Found!
Old March 16th, 2010, 16:08   #5
slate
TDI(s): Jetta
How did you get the CV joints off?
slate is offline   Reply With Quote
Old March 16th, 2010, 16:28   #6
dirtysouthjacket
dirtysouthjacket's Avatar
Take off the spring clip with a pair of needle nose pliers and a small screwdriver. Be careful because it can go flying. Then just use a plastic hammer or punch to drive the CV joint of the splines. I marked the direction first and dissambled the balls and outer cage first, before I drove off the inner. Pretty simple.
2012 Jetta TDI Premium; Dual Horn, Hybrid Grill, bunch of sound deadening to install
2004 Jetta TDI GLS - SOLD
1991 Mastercraft ProStar 190
2011 BMW F800GS, 2003 Kawasaki Super Sherpa, 1997 Kawasaki KDX200
dirtysouthjacket is offline   Reply With Quote
Old March 16th, 2010, 21:01   #7
2-Stroke Freak
With mine once the clip was removed the joint just about fell off the splines of the axle.
Old March 17th, 2010, 19:00   #8
slate
TDI(s): Jetta
I really dorked my drivers side one up. We were trying to get the transmission out and must have Conan'ed the CV joint as a ball bearing dropped out and rolled about 5 inches. Leaving a nice trail of lube.
I need to put it all back together before I can put the tranny back up.
The cage is off the races...is it possible to get the balls back in the cage and then get the cage back on race and then on the housing?
I can post a picture if it would help, but man it looks ugly.
Old March 17th, 2010, 19:02   #9
ninedee_golf_tdi
http://www.benplace.com/cv_joint_maintenance.htm
ninedee_golf_tdi is offline   Reply With Quote
Old March 17th, 2010, 19:02   #10
slate
TDI(s): Jetta
Originally Posted by dirtysouthjacket
Take off the spring clip with a pair of needle nose pliers and a small screwdriver. Be careful because it can go flying. Then just use a plastic hammer or punch to drive the CV joint of the splines. I marked the direction first and dissembled the balls and outer cage first, before I drove off the inner. Pretty simple.
Ok, I just reread this post a couple of times....So if you were able to disassemble the unit ON the axle, I should be able to Assemble the unit on the axle right?
Old March 17th, 2010, 19:08   #11
slate
TDI(s): Jetta
Originally Posted by ninedee_golf_tdi
Excellent article thanks. I don't know how many iterations of "CV rebuild", etc I searched for!!
Page generated in 0.14772 seconds with 10 queries
[Output: 95.49 Kb. compressed to 79.97 Kb. by saving 15.51 Kb. (16.25%)]
