nuuk
2000 A4 TDI Jetta 1.9L
So I have been dealing with no turbo power for months. I thought it was going into limp as when I hit about 70 going up mountains it would slowly lose power. I started looking at why and my little bit of knowledge got me no where. I checked all vacuum lines they looked good and were connected.
I took it to my mechanic and here is what he found and did. The oil line to the turbo was clogged and the turbo was leaking oil. It also sounded like a mean cat when I started the car. Diag was to replace turbo. So he installed it and cleaned everything associated with the turbo. Gave it back and I thought it was running good. A day later (1st time up the mountain) I was about half way up and I hit about 78 MPH. I was not increasing at all, but was not decreasing. I put it in 4th gear to see if I could get a little boost out of it and I lost all power and dropped to 60MPH until I got to top of mountain. It then seemed to have no turbo again. I could also hear my turbo hissing as soon as it hits 2400 RPM's. If I stick in the clutch and take it to above 2400RPMs it does not make this hissing noise. Only when in gear and moving.
I took it back to the mechanic and he said that he thinks the vacuum line to the wastegate is cracked. So he replaced that. It seem to work for a day and now it is back to hissing at 2400 RPMs. It is coming from the passenger side as when I put down both windows it clearly is coming from the passenger side.
I have no idea what to do, but wanted to ask you fine folks what you would look at next. I was thinking about replacing the wastegate since it is pretty cheap, but before I start getting crazy I thought I would ask you all. Any help would be appreciated.
Cris
Cris
