Little Stevie
Name your price.
VNT15 turbo, new, Garrett, OEM, made in France. 028145702D
AFN new intake manifold – no number, with EGR
AFN used exhaust manifold, 028253035AG, fit above VNT turbo
AFN dual mass flywheel, clutch and pressure plate, new B17400603<K>, Valeo 028141035L, Luk 028141025P
AHU single mass flywheels (2) used 037105273C
AHU clutch new Sachs 1862393031
AHU pressure plate, used Luk 412108600
Injection pumps, used:
1. mTDI pump. Approx 2000 miles. 068130107T, known good/great. Vanagon JX pump with AHU pump internals, built by Buschmeide in Germany. Includes LDA, with homemade bracket for Vanagon install.
2. AHU injection pumps (2) used 028130115G One smooth case known good but leaks, ribbed case unknown.
Toothed pulleys, used:
1. 028130111A
2. 028130111B
3. 028130111C
4. 069109111
5. No number-just MWU, big holes (AAZ?)
Ribbed aluminum pulley, used 028115021B
EGR pipes:
1. 028131521
2. 038131521B
3. 028131521P
Harmonic Balancer used 028105243T
Fan belt/water pump pulleys:
1. 037121037F
2. 028105253A (2)
AFN oil pump, OE new. 026115153A
AC/Alt/Idler bracket 028903143AB
1. 028130111A
2. 028130111B
3. 028130111C
4. 069109111
EGR pipes:
1. 028131521
2. 038131521B
3. 028131521P
1. 037121037F
2. 028105253A (2)
