Old May 6th, 2014, 12:56   #1
jasontexas
Default Any interest in a 1.5" lift?
I've been trying to find the best way to do a 1.5 lift under $100. Looking through all the ways to do a lift. I've came with $40 moog wagen springs in the rear (i have them installed now and got a 1.25 lift) and having a local machine shop make 1.5 inch spacers for the front. This will level out the car. I talk with the local machine shop and i can get the 1.5 inch front spacers ALOT cheaper if i order more than just two. So i wanted to find out if anyone else was interest in this and i could make a bigger order. Let me know if any of you are interest.
Jason
jasontexas is offline   Reply With Quote
Old May 6th, 2014, 15:28   #2
jasontexas
Also it can be any length not just 1.5 inches.
Old May 7th, 2014, 14:51   #3
Geordi
Geordi's Avatar
Location: Somewhere between Heaven and Hell. But it is really hot here in S. Florida...
Even easier option for your front end Jason:
Home Depot, the 1" galvanized pipe coupling. It is solid steel and 1.75" long. I have 2 of these on the front of my 03 wagon right now. It hasn't created any issues with my ESP in more than 1000 miles so far. Oh yeah: $4 each.
What I do have a question about for anyone that has done a decent sized lift - How much has your MPG changed? I had an unbalanced tire on this recent trip that I just got fixed, but my mileage seems to have dropped 5mpg with the lift?
At the same time as the lift, I replaced the 4 bushings on the front end, and new Monroe quickstruts that I installed the pipe couplings onto. The rear suspension is stock, except for Airlift 1000 bags inside new springs and then lifted / inflated to almost the same height as the front is now.
Sent from my iPad using Tapatalk HD
I always knew beans would give me gas. But I never expected Diesel!
Geordi is offline   Reply With Quote
Old May 7th, 2014, 15:36   #4
jasontexas
The stock struts are 7/8 inch where the spacer slides on so a 1 inch pipe will be loose. That one of the reason I have gone that route. I'm not say it won't work I'm just concerned about it being safe.
Old May 7th, 2014, 15:56   #5
Geordi
Geordi's Avatar
Loose - Thats funny. It will have the full pressure of the spring seat against it, pressing it into the bearing above. It is in NO danger of slipping sideways once the pressure is relaxed from the spring compressors.
The collar is better than just a piece of threaded pipe, because it offers a fatter seating surface and is overall thicker than the pipe. The 1" collars actually fit the bearing quite nicely, matching the overall seating-surface of the bearing nearly perfectly.
Thinking about it some more, an easy answer to the centering issue might be as simple as a fat rubber bung from home depot (they have tapered versions for $2-$3) with a 7/8 hole drilled in the center. The rubber will be compressed into the center of the collar, but it will keep the collar from moving side-to-side at all. Since the top of the spring is not moving in relation to the threaded section, the rubber compressing onto the strut shaft shouldn't matter in the slightest.
Metalnerd Lift kit + VR6 Springs Will give about 2" Total Lift tothemax Private TDI Items for Sale/Wanted 5 December 9th, 2012 06:04
Fuelab lift pumps - Interest for potential group buy? Whitbread Vendor & GroupBuy items for sale 76 December 4th, 2012 23:10
Air Lift Installed!!! Lift Pic Added DIESELprogrammer Upgrades (non TDI Engine related) 130 April 13th, 2012 16:57
Busted my Lift Pump - Does anybody have a dead PD lift pump? tothemax Upgrades (non TDI Engine related) 17 April 21st, 2009 22:54
Lift points when using 4 point frame lift Van1 VW MKIV-A4 TDIs (VE and PD) 9 September 16th, 2003 13:08
Page generated in 0.12902 seconds with 11 queries
[Output: 71.43 Kb. compressed to 63.36 Kb. by saving 8.07 Kb. (11.30%)]
