Old June 4th, 2012, 10:31   #1
rmay635703
TDI(s): 2002 Jetta
Default Dead 02 TDI jetta, garage says lift pump I say impossible.
I am wondering what common things could cause my jetta to be bricked.
Symptoms prior, lots of smoke, hard start
Now, no fuel gets injected.
I am curious what all I need to go through (simple to complex)
I am hoping a sensor went or somethings plugged and I dont' have a bad injection pump.
Car only has 110k on the clock, timing belt was done about 20k ago.
Thanx
Ryan
rmay635703 is offline   Reply With Quote
Old June 4th, 2012, 10:46   #2
belome
Fuel Economy: 47'ish
Considering your Jetta doesn't have a lift pump, I'd think you are correct.
You need to find a compotent mechanic.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old June 4th, 2012, 11:00   #3
JETaah
Fuel Economy: 53 max, 42 min, average 46
Could be they are refering to the vane transfer pump in the IP.
Not terribly likely at 110K from normal wear but stranger things have happened.
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Old June 5th, 2012, 00:54   #4
Gluhkerze
Gluhkerze's Avatar
Fuel Economy: best was 611 mile round trip to Phoenix. 60MPG on B2
Originally Posted by belome View Post
You need to find a (competent) mechanic.
^X2^
Have you done the simple stuff like replace fuel filter yet? Pull engine cover and look for leaks around IP pump & injectors? Any air bubbles in the clear fuel line to the IP pump? Was this smoke black or white?
ALH Forever!
2002 Golf TDI 2D 5-speed manual - Mufflerectomy - Panzer Plate - VanGogh - PD Engine Cover Mod - HID E-code Projectors w/ Fogs - Euro Switch - ScanGauge II - 15" Jarama OEM wheels - Blue Ox Towing Base Plate - Hidden Hitch
Gluhkerze is offline   Reply With Quote
Old June 6th, 2012, 10:03   #5
rmay635703
TDI(s): 2002 Jetta
Originally Posted by Gluhkerze View Post
^X2^
Black smoke and loss of power, intake was clean, turbo was clean.
Old June 6th, 2012, 10:17   #6
jettawreck
jettawreck's Avatar
Have you inspected the TB for condition and tension??
Did this happen suddenly or did the smoke/hard starts come gradually?
2004 Cadillac SLS (wife's)
Old June 7th, 2012, 06:02   #7
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
You COULD have blown off a lower turbo hose. If at speed when it happens it'll smoke HARD and then sometimes stall/flood out. But it could be a pump, seen them fail earlier. Any metallic ticking prior to the shut down? The pumps tick hard before they grenade.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old June 7th, 2012, 15:34   #8
rmay635703
TDI(s): 2002 Jetta
It came on gradually but on the last day it was hard to keep running and went down quickly.
Are there any reliable and inexpensive tdi mechanics in the Wausau WI area? I hate having to plunk down $1k ever year.
Old June 7th, 2012, 17:48   #9
paramedick
paramedick's Avatar
Ummmm.....Pick one. Decide what your priority is. Also depends what you're spending your $$$ on. For example, I'll charge you $225 parts/labor for front brakes using quality parts. $165 rears. I don't have a shop to support, so take that into consideration.
Old June 7th, 2012, 19:49   #10
jettawreck
jettawreck's Avatar
So, has the TB been looked at yet??
Old June 8th, 2012, 10:22   #11
rmay635703
TDI(s): 2002 Jetta
Brakes are done, motor isn't.
Also my experience lately is that I get neither, they are both expensive and unreliable, the local cheapskate was the most reliable but he doesn't work on TDIs.
Old June 9th, 2012, 20:06   #12
paramedick
paramedick's Avatar
There you go. My point was that $1K/year maintenance isn't horrible IF the car is fixed correctly.
Old June 30th, 2012, 10:01   #13
rmay635703
TDI(s): 2002 Jetta
I got the thing running but it smokes like a coal train and has no power, I didn't see anything significant in the throttle body, looks to be straight through. I don't see and hoses off the turbo.
I will need to keep looking, could injectors or injection pump cause this strange behavior?
Old June 30th, 2012, 13:10   #14
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
keep a close eye on your engine oil level
Old June 30th, 2012, 13:28   #15
whitedog
What did you do to get it running?
2009 Jetta TDI lift pump and aux pump failure NineHighline VW MKV-A5 Golf/Jettas 27 July 11th, 2011 07:13
Wanted: Dead PD Lift Pump Sooch Private TDI Items for Sale/Wanted 6 September 29th, 2009 10:55
Busted my Lift Pump - Does anybody have a dead PD lift pump? tothemax Upgrades (non TDI Engine related) 17 April 21st, 2009 22:54
Dead on road. Fuel pump or filter ? 02 5 speed 230k CaTdi2002 TDI 101 4 April 6th, 2009 09:22
my 02 jetta tdi is dead.... wllmbm TDI 101 2 July 15th, 2008 10:34
Page generated in 0.16509 seconds with 11 queries
[Output: 128.78 Kb. compressed to 107.39 Kb. by saving 21.39 Kb. (16.61%)]
