Hello to all.
New to posting, but have used you all as a resource for a few years. Thank you for all the help and information.
However, I am having some difficulty finding my satellite radio control module in my 2013 Jetta TDI sedan. Last week my radio was doing a channel update, then decided to stop working. Called Sirius to walk through some troubleshooting, no help. Took it to the dealer, not much help. They hooked it up to the computer and said they couldn't communicate with the module at all, which was my initial suspicion, since I don't even see a radio ID number in the diagnostic menu on the radio screen. So, long story short, I need a new satellite radio control module. Worth noting that every other aspect of my radio works fine; AM/FM, Aux, bluetooth, etc.
So, I researched on chiltondiy.com and was informed the satellite radio control module is under the rear parcel shelf, above the luggage area. After an hour or so of taking apart various trim parts and removing the shelf, no control module there. Called two separate dealership service centers, both said it should be under one of the two front seats. Not under either. I took the bolts out and lifted each seat to get a good look, just to be sure, and there is no satellite radio control module. The passenger seat has the bluetooth module under it, but no satellite radio control module.
Does anyone have any idea where this control module is in the is car? Any help/guidance/suggestions are greatly appreciated. Thanks.
