collector_edi
I installed the device after work in the parking garage. It took about 10 minutes. I think they did a nice job with it. Here is the video install how to that I believe is not currently published on the website.
Can't wait. Got shipping info on mine today. It is on the way!
You're more than welcome. It's a plug and play installation and there are configuration settings that I haven't poked around with as of yet. Fit and finish is awesome and I feel more connected with the vehicle. Knowing exactly what the operating temperature is and monitoring EGT's feels a bit engaging along with the driving factors of the vehicle in and of itself. Driving home EGT's remained in the range of 440 and 690. Mostly in the 4 hundreds and that commute was 37 miles.Thanks for the install pics on the Passat. It does look like its well integrated into the vent. I feel the same way about the display, its aesthetically similar to the MFI. Ultimately I really like the integrated look. collector_edi, How do you like its functionality?
Again many thanks!
I took a short trip, dropping the kids off to school, and noticed EGT's remained lower when manually shifting on an engine that was 90 degrees when pulling out of the garage. I didn't go over 40 and EGT'S didn't spike over 600. When I drove in automatic it appeared to spike higher on a cold engine. Please take this with a grain of salt as I am new to diesels and have only been in the car twice since installing.
It would appear that you're monitoring one of the downstream EGT probes and not the one pre-turbo.You're more than welcome. It's a plug and play installation and there are configuration settings that I haven't poked around with as of yet. Fit and finish is awesome and I feel more connected with the vehicle. Knowing exactly what the operating temperature is and monitoring EGT's feels a bit engaging along with the driving factors of the vehicle in and of itself. Driving home EGT's remained in the range of 440 and 690. Mostly in the 4 hundreds and that commute was 37 miles.
Nice!
That could be a problem...I won't have mine until next week, but I will get it installed as soon as I get it, and compare it to the numbers I know mine runs.It would appear that you're monitoring one of the downstream EGT probes and not the one pre-turbo.
Thanks for the code...snagged a scan gauge for the 109 price shipped free.Aaron - Check out Advance Auto Parts for the ScanGauge. They have a coupon right now "WD10" that brings the total price to $109.99. I love my scangauge and have it mounted on top of my steering column below my gauges.
You could always move "up-nort" to get more use out of the defrost and Floor heat...In Arizona,Nevada where I live I don't need anything blocking my AC vent, it gets 120 degrees in summer, I cant wait for my SG2...
I live in Las Vegas and I worried about the exact same thing. However, it has proven to be a non-issue. Partially blocking the side vent just increases the flow from the center ones which is actually more beneficial. The AC still pumps out the same amount of air, so it still cools the car just as well. What is truly useless in the desert heat is the indirect (top of dashboard) AC vent in Mk5 Jettas. Bouncing the cold air off of the hot windshield defeats the purpose of having air conditioning.In Arizona,Nevada where I live I don't need anything blocking my AC vent, it gets 120 degrees in summer, I cant wait for my SG2...
Same reason I did not get a New south boost gauge with AC mount, I need me air cold and in me face...plus the SG2 is only 100 bucks and displays all 4 perameters at once, clears and reads codes, can change backlit color, and can be mounted anywhere...I live in Las Vegas and I worried about the exact same thing. However, it has proven to be a non-issue. Partially blocking the side vent just increases the flow from the center ones which is actually more beneficial. The AC still pumps out the same amount of air, so it still cools the car just as well. What is truly useless in the desert heat is the indirect (top of dashboard) AC vent in Mk5 Jettas. Bouncing the cold air off of the hot windshield defeats the purpose of having air conditioning.
Secondly, there is no reason why the P3Cars display has to be installed in a vent. Granted, it looks more OEM that way, but the display could actually be mounted just about anywhere in view. The wire to the display is several feet long so you have your choice as to where to mount it. I actually seriously considered putting the display right into my instrument panel.
Have Fun!
Don
VeedubTDI and LokiWolf:
I left the config to what the default settings are. Car0 doesn't list the TDI engine. I'm not sure if selecting a different Car setting changes the default settings so I left a message with support.
CONFIGURING GAUGE INSTRUCTIONS:
http://www.p3cars.com/vag-install
The default config settings on the device shipped are as follows:
D.ON
EN.Y
PRO.1
U.BG.Y
SL.80
BST.F
A1.N
A2.N
CLR.C
CAL.B [never showed]
TSI [never showed]
CAR.0
Excellent. I received a follow-up email from support. The gentleman also indicated that the control box "has it's own special software." He also indicated the config guide on the website requires updating to reflect that information. He also indicated it's "plug and play out of the box, and only works for this specific car."I will verify they are reading the correct parameter when I get mine installed.
If they aren't, there will be a phone call, trust me!
What they think the EGT is, and what we actually need might be 2 different things.
Supports response when I asked if the setting was measuring pre-turbo temps or a downstream EGT probe:It would appear that you're monitoring one of the downstream EGT probes and not the one pre-turbo.
That makes sense, and they are correct that it is the best sensor to use for monitoring regenerations. I prefer to monitor the pre-cat sensor in addition to the pre-turbo sensor... pre-turbo will show you the warm-up routine as well as peak EGTs when climbing hills and whatnot.Supports response when I asked if the setting was measuring pre-turbo temps or a downstream EGT probe:
"It is the pre-cat sensor., will show over 1000 degrees F when in regen cycle. We chose that location because it is easiest to see a regen based on our testing, as it never really goes above 600 otherwise."
This is interesting. I have had mine for several years (so it is older) and it definitely shows the pre turbo EGT. This must have been something they have changed. I have to be really babying the engine to have EGTs under 600 F. Normal in town driving usually ranges from about 600 to 900 degrees. Idle EGTs are usually under 400 degrees. During regens it is usually between 1200 and 1500 degrees (above the melting temperature of aluminum). Perhaps P3Cars could make these 2 sensors selectable. It is worth asking about. Post DPF EGTs might be better for watching regens, but pre turbo EGTs are more useful for protecting the turbocharger.I am with VeeDubTDI, I would prefer it to be pre turbo, because I want to see the fluctuations. You will see the regen temps much more quickly. Not to mention once I do a delete in the future the pre turbo becomes more important.
I will be contacting support and possibly returning it. I paid too much for it not to measure the sensor I expect it to.
You could go really overboard and have both! Think of all of the data you could monitor.It's a competition between gauges, who will win, lol...
This seems odd to me. I have one in my '12 Golf and I will see over 1200 degrees in the first couple of miles as part of the warm-up cycle, and 1300+ in regen, 950 at idle during regen. I suppose it's possible that you didn't enter regen in 30 miles, but I would have thought you'd see the warm-up cycle. It's brief, so maybe you were looking at another measure. Also, at cruise (for me higher than 65) it's not uncommon to see 850-950 degrees.I took a 30 mile trip yesterday. Peak EGT was 597. Ranging speed never exceeded 65 MPH.
They don't according to their response to EDI.This seems odd to me. I have one in my '12 Golf and I will see over 1200 degrees in the first couple of miles as part of the warm-up cycle, and 1300+ in regen, 950 at idle during regen. I suppose it's possible that you didn't enter regen in 30 miles, but I would have thought you'd see the warm-up cycle. It's brief, so maybe you were looking at another measure. Also, at cruise (for me higher than 65) it's not uncommon to see 850-950 degrees.
We've got the Passat gauges showing up early next week: I'm going to ask P3Cars if they use the same sensor on that car as in the CBEA/CJAA. Don't see why they wouldn't.
