Jasonstiller
What are the odds, the dealer would know this has been done to void your warranty and what are the effects long term? Can the motor/trans handle this increase? I would love to do this but....worried
I am not knocking your tune! I am just interested in what they did to make the power. Its boost, fuel or both. The only reason I was wondering about the boost is because of the rumor of some failures and if the extra pressure created in the tune might have an effect on the life of our small turbo.I have an iPhone and a GoPoint BT1, not adding another device to the cabin. I haven't tried to get it to display boost. Isn't it an extrapolated Boost?
Not too concerned with boost. It makes more power and with a VGT, max boost isn't really where your power is, it is sustained boost. Boost won't tell me anything. It drives better and has more power.
Sent from my iPad using Tapatalk HD
Just yell, I'll let you take it for a spin.I'll have to look you up the next time I'm down in that part of the state.
I think the earlier link/pic of the dyno for a BV43 equipped 2.0 TDI - BV40 probably drops off a little sooner. Regardless, glad you're enjoying it.
Why? Millions TDi turbo cars are on road here in US and Europe. I don't see your logic behind. It's nothing wrong with turbo at high rmp, the case with Passat turbos are in cold starts and use too much boost on cold oil. The turbo will fail eventually, but it should be fine for 100,000+ miles.Is the dyno for a Passat or a Jetta/Golf? If it's a Jetta/Golf the curves may be different for the Passat. The one Passat I've seen on a dyno really ran out of steam around 4K. More so than my Golf, which is really done at 4500. Those of you that have seen dynos from my ALH know this doesn't have to be the case for all diesels.
The comment about holding wastegate closed longer doesn't make sense to me. First, it's vanes, not wastegate, although they do the same thing, kind of. But if you hold the vanes closed boost will go up. If Malone is regulating boost to 1 PSI over stock then the tune can't hold the vanes closed longer, beyond what gets that extra PSI.
Looking at the curves I'd suspect most of the increase in power is added fuel, which is also probably why they're concerned about EGTs in warmer climates. I'd personally worry about driving the car too hard without an EGT gauge to help you know when to back off. And I wonder what that added fuel does to regen frequency. I haven't seen any data on that.
And are these cars really limited to 110 MPH? I thought it was 130.
I'm interested in hearing more as people live with these tunes for a while. My Golf remains my only TDI that's stock.
That is exactly why I was asking about the extra boost they created with the tune. I do not feel there is much over building going on in diesel engines now like there was before and without a wastegate, you are at the mercey of the tuner being good enough to know how much boost he can or will make in every situation. The 6.7 powerstroke is a great example as many of those that are tuned or even just dpf deleted have had there turbos blow. They are built to hold up to the factory tune and very little more.Variable vane turbos are known to fail at high temps, 1600 degrees F is the accepted limit. If a tune adds fuel to the stock maps and allows EGTs to exceed this temperature regularly the turbo can fail prematurely.
Sure there are millions of turbo diesel cars on the road here and in Europe. And the majority of them are stock. The question is how long will they last if allowed to exceed the manufacturer's recommended exhaust gas temperatures. And most people here would be furious if their turbos only lasted 100K.
I'm actually less concerned about the turbo than the impact of added fuel on Regen frequency and DPF and DPF filter life. Tuners I've asked about this give me an "it depends" response. Hard driving will cause more frequent regens because you're dumping more fuel into the engine and therefore more to clean up down the tailpipe. If you use the power occasionally it may make no difference at all. I know of one tuned JSW owner who had two DPF filters (and ultimately the DPF) fail within 100K. Did the tune cause it? I have no idea. And it was a data sample of one.
The emissions systems we have here, especially on the Golf and Jetta, are pretty much unique to this market, and I don't know if the Passat's engine code is used anywhere else. So we may have different experiences than other markets with these drivetrains.
But do they use the same turbo in Russia?In the Russia VW is rated 170 hp so it should be a problem
That's because the Powerstrokes are altogether garbage.The 6.7 powerstroke is a great example as many of those that are tuned or even just dpf deleted have had there turbos blow. They are built to hold up to the factory tune and very little more.
I was wondering if you could do the DSG tune without anything else. I'd be interested in hearing about how well it works without the ECU tune.nothing like pushing an already stressed turbo with know production issues.
Keep reporting back as the miles pile on.
I'd be tempted for the DSG tune just to smooth it out.
Even in stock form, the 6.0 Powerstrokes are garbage. PowerJOKE, PowerCHOKE. Whatever you wanna call it.Or its because more of them are tuned than the TDI
It is pretty funny how many of us on here are also diesel trucks owners!Love mine, too. Not sure why all the hate.
The license plate is 6 LEAKER, though... for what it's worth.
You are making an assumption that the failures are due to stress and not a manufacturing defect.nothing like pushing an already stressed turbo with know production issues.
Like was said by Kevin, you can do the DSG tune by itself.
And for Ace_Deprave, the DSG tune can be done without an engine tune for the same effect.
