Byte 18 Code 1F - superseded by post #86
Forget yesterday's post, here's today's. I think that I got a better solution on this now. Tried the following codes for Byte 18 today: 1C, 1B, 31, 55, 5F, 3A, 03, 04, 06, 8C, 1D, 20, 95, 96, 97, 98, 99, 9A, 9B, 9C, 9D, 9E, 9F, 15, 21, and then 1F. Some of these were listed in the drop-down menu in our Byte 18, others I got from reading various other threads (GTI forum for one). Some worked OK, others didn't have DRL's, some turned off the trunk lid lights when opening it (thought that was kinda cool), others warned about checking the rear fog (which makes me want to keep digging for a BCM output for this, but a relay will suffice for now), rear or front marker light warnings, along with other variations, but I finally settled on code 1F. Interesting thing was that no matter the code I entered for byte 18, the coding was accepted. Some of them gave me only the right backup lamp, leading me to believe that the left 'reverse' wire was for the rear fog (had lamp warning). Another interesting feature was that the backup and amber turn signals were almost always working correctly, no matter the coding applied. The front turn signals and mirror LED's always worked correctly as well as the license plate lamps. Tail lights and DRL's are another matter entirely. Drained my battery today with all the lamp cycles I put the car through - was down to 10VDC. Charged it up and was OK. Had a bunch of error codes to clear!
I have no bulb warning or other codes on the MFA! Yay! DRL's working as expected. Seems as though the dash dimming is working again, All rear lamps working after a minor wiring change, shown in the yellow highlighted portion in this schematic. Did this to make the trunk lid lights act as brakes lights with the body lamps. No resistors either. I plan to make a nicer schematic later. I want to drive this version for the next week and see if any other bugs come up. Plus I still have half my dash torn apart! I think that I need to get those LED license lamps now to make it 100%!
And here's a new video of all rear lamps in action:
http://s1267.photobucket.com/user/vw_norm/media/Rear%20LED/RearLEDs1F_zpsed601770.mp4.html
