abctdi
Jetta is not a midsize, despite it's appearance.
That's a Golf 'test mule' used to test out the electronics, trannie and so on. Not the actual car.Could this be the new NMS?
It doesn't look like a Jetta. Maybe this link has all ready been posted in this forum and I missed it, but it seems that it’s the NMS. Only one photo, but I do not recognize that nose. Anybody else seen other photos of this black one or others yet?
It sure looks like a sedan to me. Last I checked the Golf is either a hatch or a wagon, so you've got me a bit confused.That's a Golf 'test mule' used to test out the electronics, trannie and so on. Not the actual car.
That is no Golf. Not Polo either. Not Jetta either.That's a Golf 'test mule' used to test out the electronics, trannie and so on. Not the actual car.
I'm assuming you've read the text below the picture?I think it is NMS.
I don't know why you are so certain... look at those louvred disk brake cooling ports, and the louvred panel between them. I've never seen that on any VW. Prove me wrong...Please, post a link to the year and model where you see that front fascia.I'm assuming you've read the text below the picture?
I highly doubt that this is the NMS's sheetmetal. It's a test mule for sure. The headlights are different than the A5 Jetta, that's true, but the rest of the sheet metal is clearly very Jetta like. There is no way IMO VW is going to replicate the front fascia of a previous generation.
Wheels look easy to keep clean!Finally some spy shots about the NMS. This to my eyes looks like the real McCoy.
http://www.leftlanenews.com/volkswagen-nms.html
I'd love to have that one with the 3.0. It should run like a cat with it's tail on fire!Depending on weight, the current 2.0 TDI should be fine. If urea becomes necessary due to weight, I'd rather have the 170hp version, but lets try to avoid the V6 3.0. I can't believe we would need all that power. Of course, it would be fun to dust off a 335d
No doubt there! And if the 3.0 is the only diesel available that would not stop me from buying it if all else is in place.I'd love to have that one with the 3.0. It should run like a cat with it's tail on fire!
I've owned a couple of Cutlass Supremes back in the 70s and 80s. I am sure this would run circles around themLooks like a Cutlass Supreme. Will it drive like a Cutlass Supreme?
I was thinking it looked more like a sporty Lumina (which is an oxymoron.) I would like for VW sell more units, but not if it means making cars that look like Chevies. If I wanted a Chevy, I'd buy one.Looks like a Cutlass Supreme. Will it drive like a Cutlass Supreme?
.... It's water over the dam now, but taken as a whole, that car looks 95% MK5 Jetta, especially its proportions. Given we know the NMS will be much bigger than a Jetta, it was quite apparent that your picture probably wasn't the NMS.I don't know why you are so certain... look at those louvred disk brake cooling ports, and the louvred panel between them. I've never seen that on any VW. Prove me wrong...Please, post a link to the year and model where you see that front fascia.
I will be curious to see if those louvred disk brake windows are in the air dam. I've never seen that before. Kind of looks good..... It's water over the dam now, but taken as a whole, that car looks 95% MK5 Jetta, especially its proportions. Given we know the NMS will be much bigger than a Jetta, it was quite apparent that your picture probably wasn't the NMS.
This angle from the NMS has the truck for scale shows that this is a BIG car! I agree with the author that there doesn't really seem to be a place for the Passat and this car.
I'd have loved to see the 170 go into the CC, then I would likely not have switched over to the 335d. Although, I don't see an Audi/VW V6 TDI muscling out BMWs 3.0 straight-6 anytime soon...265hp and 425 ft-lbs is formidable - the dual, sequential turbos are something.I'd love to have that one with the 3.0. It should run like a cat with it's tail on fire!
