I think I've thought of a way it would be possible to attach 2 vnt 15's to the alh with easy modification to the exhaust manifold... one turbo for two cylinders each. this VS two vnt 15's lined in series back to back instead of parallel like I described above, which would work better? How much hp could one expect?
Pondering this thought because I have two vnt 15's right now.
Here's the premise
You cut away what I circled on both turbos but on different sides, weld/fix the remaining hole.
Then one with the right side cut connects to the far right and the one with the left side cut connects to the far left (when viewing from the back of engine and turbo). Then you have them staggered and they should fit. Would two cylinders even cause enough pressure to provide boost? You could use the one n75 with a t in the line to control vnts/boost to both. Then it's a matter of working out the piping. Presumably the intake mani wouldn't have to be modified for this setup?
What you guys think? If it is somehow made to work how much power you think a twin vnt 15 setup like this could produce?
Here's the premise
