Ignition/Lock Cylinder Housing
Bengoshi2000
Triad NC, USA
2002 Golf (0M1)
So the ignition lock housing needs to be replaced on my '02 Golf. Is this job possible without pulling the steering wheel? <please say yes>
csstevej
north nj
Yes you can.
I had to do this at my sons college in the parking lot.
You will need a Dremel with a cut off wheel. I didn’t have that option , had to use a cut down hack saw blade.
You will also need two new security bolts as the heads snap off when you get to the right torque.
csstevej
north nj
Pull the steering wheel all the way out and remove all the covers.
Unplug ignition switch and the connector by the key lock.
After that you’ll see what needs to be disconnected .
With the dremel you need to cut a slot onto the head . Then with a large common screw driver unscrew the screws .
