8v-of-fury
I have never driven another ALH car, or any VNT car before owning this one.
I have a weird power band, its pretty late.. and laggy when shifting. I thought VNT's were supposed to be the almighty! lol (I understand it is likely not acting correctly..) Sometimes, I will drive 100 km (my drive to and from work) and have no boost at all, the car is a slug. I have verified with VCDS that when this is happening the ECU is requesting high boost, but the turbo is not providing. This is evidently seen with both the on board MAP as well as a mechanical gauge in the intake. Additionally, when it is doing its no boost thing it feels as though the vanes are wide open. It will reach 3500rpms and not have made any boost.. maybe 2psi.
I replaced the N75 today to be sure it wasn't just not doing what it was told. I have also tried just hooking the vacuum actuator of the turbo to straight vacuum so it will hold the vanes closed. And it is peppy around town, but 15psi down the hwy when it wants 0 at cruise and it throws limpmode.
SO now that we know the ECU is requesting the boost, the N75 has been replaced, and the vacuum source is good. I guess we must look at the turbo now. I did an N75 test with VCDS and could feel the turbo lever moving, but how far is it supposed to move?
I am unsure why it feels perfectly fine some days, and others.. it has no boost at all. I assume it should start making boost fairly early.. like 1300rpm?
