Old September 20th, 2017, 09:30   #1
mstanfield
Default 2012 TDI won't start after battery change
I'm in a bad place with my 2012 TDI 147,000 miles. Getting ready to turn the car into VW. Went to start car after sitting for several weeks and it would not crank. Tried to trickle charge (1 amp maintainer for a couple days)...would not take charge....
There is no way I'm putting a new battery to simply turn in the vehicle, so I took a good battery from the jeep and replaced. Now car cranks but no start. VCDS now has a bunch of codes (several are "status malfunction 0010) that weren't there before.
I've read about touching the leads together and saw the voodoo sequence which I haven't tried. Turn on the key and the engine fans run all the time
Can I reset thru VCDS, try the voodoo procedure, or tow the )&*% thing to VW and spend sunk money
I'd appreciate any insight
Thanks!
mstanfield is offline   Reply With Quote
Old September 20th, 2017, 11:07   #2
turbobrick240
turbobrick240's Avatar
Yeah, I'd try charging that battery up and touching the disconnected leads together.
Old September 21st, 2017, 08:11   #3
mstanfield
I'll try that...
Should I do anything to VCDS?
Old October 15th, 2017, 05:32   #4
mstanfield
Guys
I cancelled my appointment....car sits in the driveway; pretty frustrating
Here is what I've found:
I'm not getting fuel; can't hear lift pump running. I checked OHM on outside pump connector pins, reads 3.3; I "think" this is ok.
I'm not getting power to the harness that connects to pump. For the life of me I can't find a fuse box description that shows the photo and description together; plenty of google pics, but none together??
I did the computer reset...touched the battery leads; can't see any change
Can you give me some advice?
Thanks!
Old October 15th, 2017, 08:04   #5
PRY4SNO
PRY4SNO's Avatar
Fuel Economy: Impressive
If you're still using the Jeep battery you may not be getting the juice your TDI requires.
Can you boost the car with the old battery and drive it there without shutting off the ignition? Once it's at the dealership... it's their problem haha
- 2010 GSW 6 speed TDI (245k km & counting): stock... except for some BBS Madras wheels, OBDeleven coding & Dieselgeek P2015 bracket
- 1992 Audi 80q 20v: the 20vt winter sled (long term project)
- 1990 Audi Cq 20v: #becauseracecar
PRY4SNO is offline   Reply With Quote
Old October 15th, 2017, 12:28   #6
ihatespeed
Fuel Economy: 40mpg city 46 avg, 50 hwy 33 trailer
the fans running all the time with key on is a clue I think, you may have a bad ground, happened in a civic I had, lousy engine ground caused all sorts of gremlins. also double check your battery polarity, the posts may not be in the same orientation on your jeep battery vs your vw battery, if it was hooked up backwards you likely smoked some fuses.
Good Luck!
Andrew's 3rd generation (2Micron.com) return fuel filter, and Pure Flow HPFP modification.
ihatespeed is offline   Reply With Quote
Old October 16th, 2017, 19:53   #7
ricks
ricks's Avatar
Fuel Economy: 38ish mixed, 49 highway
A battery is not universal. You will need the correct cranking amps and the correct constant voltage. Check the specs of your old battery and compare. If not really close you will need to shell out some coin.
Rick S, '10 JSW TDi, '71 914-6 3.0
ricks is offline   Reply With Quote
Old October 17th, 2017, 09:11   #8
740GLE
check wiring, pests could have found their way in causing havoc. I don't like the fact you let it sit for several weeks, this is the time of year pest get all "nesty".
A jump pack with an undersized/marginally powered battery will get it running if everything is working.
Heck I was able to pop the clutch start when my battery finally gave up and hardly ran dash lights and I was late for a flight, guess it pays to live on a hill with a 150 ft driveway, I had one shot and I made it.
Old October 17th, 2017, 20:25   #9
kooyajerms
grocery getter
kooyajerms's Avatar
You need to see what your voltage is when you are cranking. If it drops off too much your keep battery may not have enough CCA. Give us the stats on the battery.
If you want to spend $100 that you get to take back after, buy one of these 1000 peak amp (doubt it's that high) jump packs that also does a good job of charging your phone, laptops and more. Get it running and dump them with the bad battery.
Miuko 1000A Peak 18000mAh Portable Car Jump Starter (up to 6.5L Gas, 5.2L Diesel Engine) Power Bank and Phone Charger with Smart Protection Clamps https://www.amazon.com/dp/B0721B3DR5..._HDS5zbW60FTWS
I can use this specific jumper with zero battery attached to the Jetta and it can turn it over.
I've tried a couple of these different units and name brand ones . The weaker ones it there couldn't even crank over my diesels. This has been THE BEST.
kooyajerms is offline   Reply With Quote
2012 Passat won't start - Help, please. cookeze VW Passat Family (NMS and B7) TDIs (2012+) 8 November 7th, 2016 15:00
Dead battery now won't start Crash4723 VW MKIV-A4 TDIs (VE and PD) 6 March 2nd, 2016 17:16
2012 Golf TDI won't start bkcmmtr VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 November 25th, 2014 07:25
New battery and car won't start! loneviking VW MKIII-A3/B4 TDIs 19 December 3rd, 2010 11:23
New Battery and Alternator - Still won't start aggiegrad TDI 101 10 April 10th, 2009 05:37
Page generated in 0.15754 seconds with 11 queries
[Output: 93.11 Kb. compressed to 79.82 Kb. by saving 13.29 Kb. (14.27%)]
