SevynDazeTDI
And yes, I've read through the no-start thread. Battery is fine and as far as I can tell, all the wiring looks good going to the starter. Doesn't appear to be a failing key switch or clutch switch. Basically I let the car on and when I go to turn it over, nothing happens. It started out like it would take a second or two of holding they key in the start position before it would crank, and once it did it would crank normally and fire right up. Now it won't crank at all, UNLESS I can some how jostle the car (like letting off the brake on a slight incline then braking once it starts to roll) while holding the ignition to the start position. This seems to work every time. Note the car is out of gear when I do this so I am not attempting to bump start it.
Any thoughts or ideas on what might be causing this and how to fix it? It's a real head scratcher for me and you guys have really come through before when I've had odd issues, hoping you gurus can help me out again. Thanks!
