Old September 16th, 2017, 05:38   #1
basswagon
Default p268a
CEL came on yesterday for the first time ever with code p268a.
All I can find is it means Fuel Injector Calibration not Learned/Programmed.
A search of this forum comes up empty, as does a google search for TDI's in particular.
The car starts and runs ok, though mileage seems to be down a bit.
Any thoughts?
Thanks!
basswagon is offline   Reply With Quote
Old September 16th, 2017, 22:12   #2
super1
TDI(s): none
Default p268a
Found this:
It keeps throughing p268A fuel injector calibration not learned/programmed intermittent. Last visit the ECM was replaced as per level 2 tech line and I think he replaced injectors. I'm just wondering if anyone is familiar with this code thanks in advance
Поделиться
8 comments
presumptive6865 August 10, 2016 17:16
Did you program injector serial numbers to ecm? Test plan for it.
^8upsurge^_ August 10, 2016 17:17
Yes
guile199907 August 10, 2016 17:20
Harness issue. We had one here a while back, tech overlaid the wiring from the injectors to the ecm and it fixed it. Car had ecm and injectors replaced prior to the wiring
^8upsurge^_ August 10, 2016 17:42
Todd Bitterman
Todd Bitterman
^8upsurge^_ August 10, 2016 17:43
That's what I figured we would do next. Thanks for the confirmation
presumptive6865 August 10, 2016 17:43
If it's had a ecm and injectors, time for an engine harness
Cars
super1 is offline   Reply With Quote
Old September 17th, 2017, 15:13   #3
basswagon
Thanks for that.
No re-occurrence since clearing the code about 200 miles ago.
Page generated in 0.11978 seconds with 10 queries
[Output: 52.76 Kb. compressed to 47.72 Kb. by saving 5.04 Kb. (9.55%)]
