Old September 12th, 2017, 12:51   #1
IDoSeaDoo
Default MK6 Jetta TDI - Front strut mount clunk
Hey guys,
I've been chasing a clunk for a year now and tracked it down to the strut mount. When I take off, and sometimes when I slow down, I hear a loud click/clunk from the suspension. I've replaced the dog-bone mount, the lower control arm bushings, and checked everything else. The clunk has not improved, so it's got to be the strut bushings. Now, the dealer sells the mount, and the bearing that goes inside separately. The question I have is, what part goes bad? I don't want to replace good parts if I don't have to, and this car isn't that old yet. I've never had a car that needed these replaced, so it's my first time dealing with this issue. Does anyone have any experience on the matter?
IDoSeaDoo is offline   Reply With Quote
Old September 13th, 2017, 14:51   #2
crashtested
crashtested's Avatar
Sure it's not the spring? Both of our fronts went and sounded the same.
MKIV
Outback
crashtested is offline   Reply With Quote
Old September 14th, 2017, 07:03   #3
IDoSeaDoo
How can you tell a spring is bad? I've never heard of that before.
Old September 14th, 2017, 07:18   #4
phantom1260
Have you checked the end links? Both ends links needed to be replaced on my 2010 Jetta.
How do you know it's not the strut itself? Are there any signs of a leaking strut?
phantom1260 is offline   Reply With Quote
Old September 14th, 2017, 08:28   #5
IDoSeaDoo
Nope, struts look good, and the car rides over speed bumps well, the dampening is good on both sides (tested independently). But the right side gives that clunk.
Old September 14th, 2017, 08:43   #6
crashtested
Visually, or audibly.
Broken front coil springs
Third Broken Spring!
Incidence of broken springs
Broken rear coil spring
2011 rear spring replacement
These were the 1st 5 that came up on the search. Probably 10+ more after that.
MKIV
Outback
Old September 14th, 2017, 13:28   #7
IDoSeaDoo
Holy crap! I'll be sure to check as soon as I have a chance... so apparently those bearings do fail... strange. It's not like they do a lot of spinning... I feel like the MK6 was the poorest made car of all the TDI's
Old September 15th, 2017, 06:10   #8
IDoSeaDoo
Well, I checked the spring, and there is no obvious break in it, but the clunk is present as ever. I noticed that the boot on the sway bar links is a bit torn, but when I took them off to inspect, they were solid as can be, no play in the ball joints at all. Could they still be bad despite feeling okay?
Old September 24th, 2017, 17:44   #9
Gizzmo_jr
TDI(s): None
Man your story sounds exaclty like my car.
I replaced struts complete with bearings (Monroe Quickstruts), both wheel bearings (kinda needed) and checked the play of the ball joints.
Tested the TTY bolts for the sub-frame, wasn't the sub-frame clunk.
Ends up it was the cheapest and easiest part which when unladen, I didn't feel was a problem. Sway bar end links! The boots were in perfect shape.
Shake my head at that one, 30min to do both and never heard a clunk again.
2010 Golf TDI OEM+ (gone)
Gizzmo_jr is offline   Reply With Quote
Old February 4th, 2018, 19:32   #10
IDoSeaDoo
Oh man, I hope it's the struts, as I already bought a whole set, and the strut tower mounts. Can't return it as I've had them for months now...
Old February 7th, 2018, 11:26   #11
calimustang
yep same issue. Sway bar end links, drivers side was bent. pass side was worn out. replaced, problem solved. I am happy now.
2011 JSW TDI bought in Aug 13th 2010, retired with 281,535 miles, on process of buyback. will be sorely missed.
2015 Passat TDI with 22k miles, completely stock. Black exterior and black interior, will add tint and black out the wheels.
calimustang is offline   Reply With Quote
Old February 7th, 2018, 17:25   #12
IDoSeaDoo
I checked them. I unbolted one end on each side, and the links felt pretty sturdy. Not loose or bent. When you removed the old ones, were they loose? Did they obviously appear to be bad, because I could swear that mine are good.
Old February 13th, 2018, 15:28   #13
Wascally Wabbit
TDI(s): 2010 TDI
I had the same problem. For me it was the bearing. When I pulled the strut the bearing was actually broken into 3 pieces.
Wascally Wabbit is offline   Reply With Quote
Front strut mount questions 97stroker VW MKIV-A4 TDIs (VE and PD) 15 January 5th, 2017 01:55
Front Strut Mount Problem Kawayanan TDI 101 16 August 2nd, 2016 22:21
Front strut clunk neversatisfied VW MKIV-A4 TDIs (VE and PD) 4 February 8th, 2015 06:32
Golf Mk6 front suspension clunk, need some help! jayz VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 September 5th, 2014 23:48
Front strut mount Johhny04 VW MKIV-A4 TDIs (VE and PD) 2 April 14th, 2008 13:12
Page generated in 0.17210 seconds with 11 queries
[Output: 111.12 Kb. compressed to 93.32 Kb. by saving 17.80 Kb. (16.02%)]
