Old September 10th, 2017, 18:14   #1
k98shooter
Default Please Help, Oil Everywhere
My wife calls me 100 miles away that low oil warning light came on the dash. I did oil change three days ago and my first thought was I didn't tighten the plug well enough. Got there, opened the hood and whole engine bay is wet with oil. The engine cover, oil collected on the lid of fuel filter reservoir, intercooler wet. I checked oil filter lid the seal is in correct place and it was screwed in tight. I doubt it has anything to do with the oil plug, I could feel it is finger tight but I couldn't get under the car to get wrench there. Any suggestion much appreciated...
k98shooter is offline   Reply With Quote
Old September 10th, 2017, 18:29   #2
travis45
travis45's Avatar
Picture? The oil cap was in place?
14 Sportwagen TDI CR170 Frankenstien hybrid 2056 Turbo, Rawtek turbo back exhaust, Malone Stage 3, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, H&R 22mm rear sway bar, PolarFIS. Soon to install Darkside intercooler and piping, Wavetrac LSD, GTB2260vklr, Colt billet cams w/upgraded springs, ARP Headstuds.
travis45 is offline   Reply With Quote
Old September 10th, 2017, 18:46   #3
k98shooter
Oil cap was in place. I didnt take pictures, left the car there and heading home, thinking what to do tomorrow... I am wondering if it could be oil line going to or from turbo.
Old September 11th, 2017, 10:00   #4
Ol'Rattler
Ol'Rattler's Avatar
Sometimes people will install the o-ring on the filter cap incorrectly and can have a pretty massive oil leak. What they do is get the o-ring up past the o-ring groove on the cap. If you had to reef on the cap to get it to seat, the o-ring is above the groove.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old September 11th, 2017, 10:08   #5
jetlagmech
TDI(s): 2010 jetta
Fuel Economy: best tank 50.6, worst 36
Turbo oil line is a good guess, look at the dipstick tube also. But yours seems too new to have that problem yet. did you check to see how low the oil actually is ? even just a quart of oil spread over the top of engine and dripping will look like gallons.
JETLAGMECH
2010 jetta, 6sp man, & tdiclub plate frame ..build date 08-09
1956 Buick Special (my dad bought it brand new)
1946 Luscombe 8E
jetlagmech is offline   Reply With Quote
Old September 11th, 2017, 10:46   #6
k98shooter
Well, hopefully I find soon. Towing estimate to my place from where the car broke down was approx. $400.So I opted to have it towed to an independent shop, which was 20 miles from where I left the car. According to the website, they specialize in Audi/VW, (JA Autowerks in Shrewsbury, NJ). Will update on diagnosis..
Old September 11th, 2017, 14:41   #7
samarai
John who owns JA Autowerks is excellent. I only used him when I had my Golf TDI, never saw the dealer. Good luck.
samarai is offline   Reply With Quote
Old September 11th, 2017, 16:22   #8
turbobrick240
turbobrick240's Avatar
My money is on a mis-seated oil filter canister o-ring as well. It would spray oil as described, and fits with the recent oil change.
Old September 11th, 2017, 16:42   #9
hughesjasonk
hughesjasonk's Avatar
Fuel Economy: ?? Drive it like you stole it ??
This ^^^^^
AAA FTW
Sent from my SM-G930V using Tapatalk
hughesjasonk is offline   Reply With Quote
Old September 13th, 2017, 18:42   #10
k98shooter
Indeed it turned out to be a leak from oil filter canister, due to incorrectly installed O ring - per John the owner. I feel embarrassed - same thing happened when I did DSG oil change fisrt time - the canister O ring against flange instead of its designated groove and I had massive DSG leak. But this was 8th oil change, and I should have known better. I am happy at the same time that it seems major damage was avoided. I am not sure how I am going to clean the mess in the engine bay, though. Thank you all for the inputs!!
Old September 14th, 2017, 03:17   #11
calimustang
Whew glad nothing's serious.
2011 JSW TDI bought brand new on 8/13/2010, retired 281,538 miles, turned in on 7/6/2018. sorely missed.
2015 Passat TDI with 22k miles on 5/6/2018, completely stock. Black exterior and black interior, 5% tints all around. Now 30k on 8/12/2018.
calimustang is offline   Reply With Quote
Larger Oil Cooler and Remote Oil Dual Oil Filter with By-pass Filter G60ING VW MKIII-A3/B4 TDIs 24 December 5th, 2017 14:33
Oil light, after change. Plenty of oil. Oil Pump? Chris NF VW MKIV-A4 TDIs (VE and PD) 6 September 1st, 2008 18:37
Waste Oil Heater Burns veg oil, motor oil, biodiesel etc Murphy2000 Private TDI Items for Sale/Wanted 5 February 11th, 2007 17:48
OIL Light on, but theres oil in there - no power, think turbo is blown, or oil pump Starving_Student Fuels & Lubricants 39 January 28th, 2007 08:06
Oil change with oil extractor - used oil amount? TDI-NC VW MKIV-A4 TDIs (VE and PD) 6 April 26th, 2004 22:16
Page generated in 0.17220 seconds with 11 queries
[Output: 100.77 Kb. compressed to 85.02 Kb. by saving 15.75 Kb. (15.63%)]
