Old September 6th, 2017, 09:02   #1
WilliamDonald
Default 2012 VW Golf TDi duel mass to Single mass conversion Valeo
After the second dual mass conversion flywheel broke 250,000 had a single mass clutch installed. Getting a whining noise in 5th and 6th gear. Fluid changed and still whining. Any thoughts?
WilliamDonald is offline   Reply With Quote
Old September 9th, 2017, 10:33   #2
Mattyoctavia
The bearings are going in the gearbox it sounds to me. I don't think the boxes can handle a solid flywheel.
Mattyoctavia is offline   Reply With Quote
Old September 10th, 2017, 00:10   #3
Henrick
I've heard that SMF setup hammers synchros.
250k miles is not bad for two DMFs. If DMFs are failing frequently, check your driving habbits and style.
Henrick is offline   Reply With Quote
FS: mkV Valeo clutch and single mass flywheel conversion siucamt Private TDI Items for Sale/Wanted 0 April 18th, 2014 20:48
dual mass flywheel failure/single mass conversion bassman5066 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 October 22nd, 2012 14:41
Stock 2002 TDI clutch, single mass or dual mass??? ItsADiesel TDI 101 5 June 10th, 2012 17:48
ALH VALEO clutch+single mass flywheel, nozzles +more bikerboyriley Private TDI Items for Sale/Wanted 9 February 10th, 2012 13:24
Valeo single mass swap bolts laminated VW MKIV-A4 TDIs (VE and PD) 0 May 11th, 2009 09:28
Page generated in 0.11885 seconds with 11 queries
[Output: 56.30 Kb. compressed to 51.18 Kb. by saving 5.12 Kb. (9.09%)]
