Old May 10th, 2016, 18:11   #1
Vanigh
Default EGR P0401 - 001 Insufficient Flow
Check engine light came on, VCDS diagnostics as follows.
1 Fault Found:
001025 - EGR System
P0401 - 001 - Insufficient Flow - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 93032 km
Time Indication: 0
Date: 2010.09.13
Time: 15:05:52
Freeze Frame:
RPM: 2369 /min
Speed: 93.0 km/h
Voltage: 14.29 V
Load: 76.5 %
Load: 100.0 %
Mass Air / Rev.: 390.0 mg/str
Mass Air / Rev.: 440.0 mg/str
Readiness: 1 1 0 0 0
Is it possible that EGR System error coming from DPF?
Vanigh is offline   Reply With Quote
Old May 10th, 2016, 18:31   #2
emerscape
Could be exhaust flap or your DPF is shot
emerscape is offline   Reply With Quote
Old May 11th, 2016, 03:22   #3
meerschm
meerschm's Avatar
http://forums.tdiclub.com/showthread.php?t=445921
check the above link.
your DPF could be cracked, causing the low pressure EGR filter to clog up, (what does the tailpipe look like, what do you get if you wipe a paper towel inside the tailpipe?)
Mike
Free advice: it is worth what you pay for it. (sometimes)
meerschm is online now   Reply With Quote
Old May 11th, 2016, 05:13   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
There is probably 20+ threads on this already. There has been a TSB about this for a while now.
Your EGR filter tube is clogged, because your DPF is cracked and allowed soot to get in and clog the EGR tube. Your tailpipes are also sooty.
At the present time, though, with Dieselgate going on, you may want to sit tight and at least wait another month or so to see what all becomes of this.
The DPF is under the 8yr/80k warranty, if you are still under 80k miles just take it to the dealer (you may want to have that page of your manual handy to "remind" them of your car's warranty coverage). Canada may not be the same, though.
oilhammer
www.cardocautomotive.com
Old May 11th, 2016, 05:34   #5
meerschm
meerschm's Avatar
Have you ever seen a P0401 error from the high pressure EGR?
(not from a cracked DPF)
Mike
Old May 11th, 2016, 05:59   #6
oilhammer
oilhammer's Avatar
Nope. Literally the ONLY thing on a CBEA or CJAA TDI I have ever seen on one for the P0401 is a clogged EGR filter tube. And I have probably seen that 100 times. We have five customers in the "wait-and-see" mode now with them, plus my own 2010, coworker's 2009, and the 2009 I recently sold (that one got the DPF deleted).
oilhammer
Old May 11th, 2016, 14:26   #7
Vanigh
Exclamation
2 Weeks ago the Dealer replaced or fixed the exhaust flap since i had CEL, the job was done under warranty, now i have intermittant CEL P0401 code. Yes there is soot in the tail pipe, dealer says the DPF is not covered under the extended warranty, i contacted VW Canada by email, I was told that the DPF is covered for 8 years or 130.000KM in Canada, i have 93500 KM on the car, i was also told that i have to take the car to the dealership and let them run the diagnostics and see what they come up with, EGR Valve is not covered under warranty any more. VW does not recognize VCDS output results.
I take the car to Stealership tomorrow.
Old May 11th, 2016, 15:50   #8
meerschm
meerschm's Avatar
Thank You
Mike
Old May 12th, 2016, 04:56   #9
oilhammer
oilhammer's Avatar
Originally Posted by Vanigh View Post
2 Weeks ago the Dealer replaced or fixed the exhaust flap since i had CEL, the job was done under warranty, now i have intermittant CEL P0401 code. yes, the low pressure EGR system cannot operate without the exhaust flap. That is what that exhaust flap's primary function is: to force the exhaust back into the low pressure EGR system. So it would be totally plausible that your EGR system test could not be run by the ECU with a bad exhaust flapYes there is soot in the tail pipe, dealer says the DPF is not covered under the extended warranty I am not talking about anye xtended warranty, I am talking about the normal factory warranty. Read your manual, it will be in there. In the USA, it VERY CLEARLY states the catalytic converter AND the diesel particle filter are covered for 8 yrs/80k miles, i contacted VW Canada by email, I was told that the DPF is covered for 8 years or 130.000KM in Canada, i have 93500 KM on the car,correct, so it is still under warranty, case closed i was also told that i have to take the car to the dealership and let them run the diagnostics and see what they come up with, EGR Valve is not covered you do not need an EGR valve, I can pretty much guarantee it. Have the dealer print the TSB, or better yet, find it yourself and print it and carry it in to them. It is a very simple, very clear, very cut and dried issue. They even have pictures if the staff at your dealer cannot read at a 4th grade level. under warranty any more. VW does not recognize VCDS output results. scan tool type is not relevant here. While VCDS does use all the same native communication and test protocols as the factory scan tools (many VW techs even have their own VCDS), the DTC and such is a function of the car's ECU, not the scan tool. A DTC is a DTC, it is stored in the ECU, not the scan tool
Bold is mine. Be persistent, and be polite. For reasons I cannot fathom, many Volkswagen dealerships' initial reaction to a warranty item is to deny. I guess they figure if the customer will pay for it, they are better off. While I have LONG since lost count of how many times this has happened, and how many times I have sent Volkswagen owners back to a dealer for a warranty item, I do know that they are generally successful. It just takes some prodding.
Just last week I had a car in exactly like yours, was already at a dealer, they told them the same thing is wrong with their car as what I am telling you is wrong with yours... only they had the audacity to tell the owner he'd have to pay for it. After he was picked back up off the floor, he found us, and brought the car here. While I could fix his car cheaper than the dealer could, I informed him that due to his low mileage (72k miles in this case) his car was still under warranty, and he needed to go back to them. He called VoA customer care first, verified what I told him was correct, and then went back to that same dealer and insisted they fix the car. When they balked, he gave them the customer care case number. They immediately repaired the car, and they of course had all the parts in stock because it is so common.
oilhammer
Old May 13th, 2016, 13:04   #10
MÄDDNESSS
I've seen this twice.
The EGR filter wasn't clogged. However, the DPF was cracked, causing too much flow through the EGR filter.
I have HEX-USB+Can & HEX-NET. If you need/want VCDS things done, PM me.
'09 JSW w/DSG. CR170 turbo + CR tune. Tyrol Sport caliper stiffen kit, F&R Tyrolsport SS braided brake lines, StopTech rear slotted rotors and green stuff pads, Kurt trailer hitch.
MÄDDNESSS is offline   Reply With Quote
Old May 13th, 2016, 13:28   #11
CNGVW
Location: Bob Mann Auto, 111 High St, Pembroke MA 02359
Fuel Economy: Built a 2002 TDI Jetta that got 120 mpg of diesel using a CNG blend.
The EGR filter is not a real filter. It has a supper fine steel pressed mesh .
It is in the system so when the ex flow pressure after the DPF and the pressure in the EGR cooler is out of balance. It knows the EGR filter has trapped soot in it. this = cracked DPF.
The only way to get soot in to the tail pipe and EGR filter is a cracked DPF !!!
I have build and sold or installed over 40 EGR Filter test kits so far to shut off the P0401. And not A one has come back!!
Bob Mann
www.DRVOLKS.com
bobtec@comcast.net
VW and Audi Master Technician and TDI Specialist. Bob has over 35 years of experience in the field, and is listed on TDIclub.com as a trusted TDI Mechanic.
Bob is also known for his CNG conversions and is a consultant for Patrick Racing.
CNGVW is offline   Reply With Quote
Old May 13th, 2016, 14:36   #12
Vanigh
I took the car to the dealer today early in the morning to install a new the DPF and the EGR. the DPF wasn't cracked but Clogged...
After contacting VW Canada the DPF became under extended warranty issue with the dealer!!! so they replaced it under the extended warranty, i had to pay for the EGR part which came to Cdn$504 including labor and taxes.
My question is, an accessory/part of the car (DPF) that is under extended warranty damaged EGR which is not under warranty, what the law says, the owner pays for the damaged part/EGR?
Old September 19th, 2017, 23:20   #13
theneild
They won't fix the dpf for the emissions recall. Mine's been throwing a CEL for years and I finally have to fix it. They won't do the recall with a bad DPF.
theneild is offline   Reply With Quote
Old September 20th, 2017, 14:41   #14
CNGVW
You will need it to pass the check engine light off for them to do the fix.
So you still can do my fix then set the readiness clean the tail pipe get the upgrade parts. after a few weeks the light will come on and you can then go back to have them fix it on there dime.
Bob Mann
www.DRVOLKS.com
bobtec@comcast.net
Old March 8th, 2018, 08:18   #15
sdeabs
While there are many threads about TDI emissions systems and troubles with DPF this thread is particularly interesting to me.
I took my 2010 to dealer for recalls with MIL on. Service rep warned me that they would not be able to complete recalls if I needed a DPF. However, they cleared the codes and completed recalls without needing any further repairs. Did not need to replace the DPF. Shortly after getting it back it started throwing P0401-001 and P2002-007. Occasionally, P0401-002 and P240F-000 too.
Ash volume is 150ml. Soot load has varied between 20 and 1.2. I have run emergency regeneration several times to get soot load down and can clear codes for awhile but they keep coming back.
Car has 150K miles and not under warranty unless recall imparted additional warranty on emissions system. So...I will attempt to check EGR filter in accordance with TSB. Any other ideas??
Scot
2006 Jetta MKV TDI - 5 speed manual - 289K – total loss 08/20/2013
2010 Jetta MKV TDI - 6 speed DSG
sdeabs is offline   Reply With Quote
code p0401, egr insufficient flow aflorey VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 24 August 2nd, 2013 04:32
P0401, EGR insufficient flow intermittent. Metalhead VW MKIV-A4 TDIs (VE and PD) 5 December 16th, 2012 14:22
P0401 Insufficient EGR Flow jajohn VW MKIV-A4 TDIs (VE and PD) 8 September 28th, 2012 04:41
P0401 - Insufficient EGR Flow jayreading VW MKV-A5 Golf/Jettas 0 June 17th, 2012 20:17
P0401 EGR insufficient flow - questions famelec TDI 101 4 November 21st, 2009 06:05
Page generated in 0.17492 seconds with 11 queries
[Output: 135.28 Kb. compressed to 114.00 Kb. by saving 21.28 Kb. (15.73%)]
