Old September 16th, 2017, 17:32   #136
respond2us
Got my Malone Stage 2 installed. Seems nice, but looks like my fuel economy is down by 2-3mpg after the emissions fix. Boo!
Got my wife's JSW emissions fix done also.
'10 JSW 6speed w/Sunroof 95k miles (Owned since 7-2-2016) -- TorkLift EcoHitch, Malone Stage II, DG Sigma Six shifter
'10 JSW DSG w/Sunroof and Nav 67k miles (Owned since 9-2016) Garage/Gate controller from Double Apex
respond2us is offline   Reply With Quote
Old September 16th, 2017, 19:54   #137
calimustang
TDI(s): 2011 JSW DSG
no way. it should increase. do you still have EGR? Do you have CP3 pump?
2011 JSW TDI, 266k miles as of 1/4/2018 - had original HPFP to 240k. White with cornsilk beige interior, still on original turbo, DSG, 16" Steelies Wheels, solid metal roof. Mods: CP3, 5% tints all around. P3 gauge, Stage 2 Malone tune and DPF/EGR delete
calimustang is offline   Reply With Quote
Old September 16th, 2017, 20:11   #138
respond2us
I expected it to increase also. Still have my egr, no cp3 pump yet.
Old September 18th, 2017, 04:47   #139
pkhoury
That guy with the goats
pkhoury's Avatar
Fuel Economy: CR - 36-41, PD - 39-48 (26-32 while towing)
Originally Posted by toneman View Post
Oil/filter change, brake fluid flush, wheel alignment and a fresh set of Conti ExtremeContact DWS. Still debating the fix.
You can't go wrong with ExtremeContact DWS. I have the DWS06 on my JSW, and LOVE 'em. One my second set, which seems to last right around 50K. Handling is absolutely fantastic when it's raining, too!
2010 Jetta Sportwagen - Malone DSG tune, Malone Stage 3.5, CR170, buzzken 3" straight pipe(resonator deleted), PolarFIS, Panzer plate, front and rear fogs, Bosal towhitch, Bilstein B8/Neuspeed 28mm swaybar, 2micron CP3 upgrade kit
2004 Golf GLS 5MT -
Malone Stage 4, VNT17, DC Stage 2 clutch, buzzken 2.5" straight pipe, MFA cluster swap, dieselgeek Panzer plate and short shifter, Bosal towbar, Tekonsha P3 brake controller, Hopkins short-proof trailer light converter, darkside SMIC, intake manifold, and tip pipe, PD150 airbox
2005 Jetta Wagon GLS (mom's car) - Malone Stage 4, VNT17, MFA cluster swap, Panzer Plate, buzzken 2.5" straight pipe, darkside SMIC
2015 Golf Sportwagen TDI (mom's car) - stock for now...
Other diesels:
Ford 5900 tractor
Ford 3400 Industrial tractor
2016 Mahindra XTV (1L Kohler diesel)
pkhoury is offline   Reply With Quote
Old September 18th, 2017, 04:49   #140
pkhoury
pkhoury's Avatar
Originally Posted by jesssssser View Post
Did you do the TB and HPFP yourself? Im at 95K so these things are on my radar.
Did ya have have to make and ECU changes w/ the new fuel pump?
Good Stuff!
No, and no. I had my TDI guru do that for me. I probably could've installed the HPFP myself, but I'm not yet confident enough to do the timing belt by myself.
I believe Owain from Malone said that a ECU tune isn't needed for the CP3. I also could be wrong, but Polar FIS reports lower EGTs (post turbo anyways). The car also accelerates A LOT quicker and a lot smoother. The difference is definitely noticeable.
2004 Golf GLS 5MT -
Other diesels:
Ford 5900 tractor
Old September 18th, 2017, 04:51   #141
pkhoury
pkhoury's Avatar
That's one of your problems. Why keep the EGR? I didn't think diesels were regulated by emissions testing in OK, though I could be wrong. I can't wait to do a full delete on my mom's Mk7; I got her spoiled on her Mk4 after we deleted the EGR and everything else.
2004 Golf GLS 5MT -
Other diesels:
Ford 5900 tractor
Old September 19th, 2017, 07:05   #142
calimustang
for CP3 install, no VCDS needed. Just plug it in and go! CP# is the best mod I ever done. Wish I did this a long time ago along with the Malone 2.0 tune.
Old September 19th, 2017, 07:11   #143
respond2us
You're correct about emissions in Oklahoma. No testing at all. And no reason to keep the EGR, other than removing may void the extended warranty from the emissions fix? Not sure about that...
So, removing the EGR hops up the power and fuel economy a lot? I haven't looked into doing that.
Page generated in 0.13076 seconds with 11 queries
[Output: 89.66 Kb. compressed to 77.50 Kb. by saving 12.16 Kb. (13.56%)]
