Old November 10th, 2015, 10:03   #61
gloaming
gloaming's Avatar
Fuel Economy: 25-35mpg city and 45-55mpg highway.
That's what I was afraid of. I think the VW techs would be scratching their heads pretty hard trying to bolt a DPF to my turbo
gloaming is offline   Reply With Quote
Old November 11th, 2015, 20:06   #62
TDIA3
is there any word on these kits being available to purchase? thanks
TDIA3 is offline   Reply With Quote
Old November 11th, 2015, 20:29   #63
ATR
ATR's Avatar
Look at post #60 in this thread (two posts above yours)
detailed explanation here:
http://forums.tdiclub.com/showthread...367804&page=17
Posts #243 & 246.
Drivers Wanted
-2011 Golf TDI 6MT = gone but not forgotten!
-2017 Golf GTI Sport 6MT
***Official maintenance schedule for your VW [PDFs inside]***
ATR is offline   Reply With Quote
Old December 7th, 2015, 08:46   #64
edgewatertom
edgewatertom's Avatar
I installed mine this weekend!
2001 - Jetta - 5spd - Galactic Blue - Grey - 303k
2003 - Golf - Auto - Grey - Grey - 154k
2010 - Jetta - 6spd - Salsa Red - Black - CP3 - 153K
2016 - GMC - Canyon - Duramax - SLT- Quad Cab - Short Box - Black - Black - 14500
Last edited by edgewatertom; December 7th, 2015 at 08:52. Reason: Not enough smiles
edgewatertom is offline   Reply With Quote
Old December 7th, 2015, 09:23   #65
YukonLT
Veteran Member - TDIClub Enthusiast
YukonLT's Avatar
Fuel Economy: Good
Congrats! How did the install go for you? Install it yourself?
YukonLT is online now   Reply With Quote
Old December 7th, 2015, 09:42   #66
edgewatertom
Thanks!!! Yes, I did the install myself. First time wrenching on this car other than maintenance.
The hardest by far was figuring out how to get the EGR/ASV out of the way. Once I figured out that the hose under the ASV could actually be removed, I read it couldn't , I could access the ASV bolts and then the EGR bolts. Granted it wasn't easy to get the hose out of there, but once I did, it was game on.
I also did the timing belt and added the 2micron lower timing belt cover at the same time.
I posted a few pic in my album from the install. Happy viewing.
What a fantastic kit and the feeling that goes with knowing I removed that ticking time bomb is priceless.
Andrew (2micron) keeping TDI's on the road.
Old December 7th, 2015, 16:00   #67
elitegunslinger
elitegunslinger's Avatar
Fuel Economy: 50.0
This is beyond awesome... Now how much was it out the door for parts? I heard something about these being pretty good with a turbo upgrade
elitegunslinger is offline   Reply With Quote
Old December 7th, 2015, 16:11   #68
2micron
TDI(s): None
Hello Elite!!!
Drop me an email, lets Chat!!!
tdi2micron@yahoo.ca
Fantastic install!! Great Job edgewater!!!
Folks, this fellow quietly bolted this kit on over the weekend, then sent his wife out to work on a long Journey Monday Morning.
Awesome!!
Thanks,
Andrew
2micron is offline   Reply With Quote
Old December 8th, 2015, 10:39   #69
Black tdi cup
Default how to buy cp3
Just curious where to actually buy the cp3 fuel pump
Black tdi cup is offline   Reply With Quote
Old December 8th, 2015, 11:07   #70
YukonLT
YukonLT's Avatar
Fuel Economy: Good
Contact 2Micron for any type of inquiry like that.
Old December 8th, 2015, 21:44   #71
TDIA3
Installed mine last weekend as well.
Loving it
I am working through some tweaking of the tune with Mark and Ben but so far this A3 is a BEAST!! One of the best Modifications Ive done.
I've done too much to this car HAHAHAH.
Y'all can check out the half way thread i started.
http://forums.tdiclub.com/showthread...06#post4938806
Old December 10th, 2015, 17:50   #72
WalkingDrunken
WalkingDrunken's Avatar
TDI(s): NONE
So this last weekend I started in on doing my install of my CP3, 1 Micron filtering kit, Fluidampr, and timing belt protector. This was the second time I was completing this project since I helped Schriebers install his CP3 before. This made me feel overly confident and led to mistakes that I’ll get to.
First….Here are some pictures of all the parts that I had ahead of time.
You might notice that I have two timing belt protectors. The raw finished one I got from Ken (Buzzken) but couldn’t fit the Fluidampr. I let Andrew (2 Micron) know and he had a new batch that he just got done with so he sent the black anodized one with the rest of my adapter hardware.
I know I was a pain for Andrew. I was waiting for my kit for over 3 months and I pestered him at least once a week to see where he stood with production. Lucky for him my e-mails were going to his spam folder. hahaha.
Here are some pictures of my engine before install.
Andrew provides a pretty complete instruction document when you order the kit from him. If you are mechanically inclined you’ll be able to follow everything and the job goes very smoothly.
Edit: I want to make one reinforcement comment about the instructions. Please please please use your finger and put a layer of anti seize on both sides of the adapter plate. The adapter plate is aluminum and sandwiched by steel on both sides. The last thing you want there is corrosion.
There are a couple parts that I got frustrated with the first install through and the second time through. Removing the Auxiliary pump wasn’t difficult but I could never figure out what it was getting held up on. Here is a picture to give you an idea of how it’s all lined up. The rubber brackets hold the pump in the above metal bracket very securely and from what I remember there is no nuts or bolts that specifically hold the pump in there.
There are two screws that connect the power leads, positive and negative. I think they are 7mm and 8mm...yea, they are different sizes…
The other area that was frustrating was trying to get the adapter on the fuel pump torqued down. I am pretty sure that I got close to the recommended 95 ft lbs using a torque wrench and pulley holder but my holder bent a little and kept slipping. I made sure my porter cable electric impact was fully charged and gave it a few quick goes at it to top it off.
The timing belt video done by myturbodiesel.com is priceless. When you use it and finish your install I would highly recommend donating. It is that helpful.
https://www.youtube.com/watch?v=fAi667H7M2Y
A few notes with the timing belt. You can technically skip some steps if you are reusing the same belt. I would highly recommend not to. This was my mistake. I thought I remembered what I was doing from the first install and didn’t get the belt reinstalled correctly. I was able to start it without causing damage but it sounded like a tin can with nuts and bolts inside. It was confusing, scary, and nerve wracking all at the same time. I started the video over and went step by step over everything. Got it back together perfectly.
When you get everything installed and try to start it for the first time you need to prime the fuel system. Obviously there’s no fuel in any of the new parts you just put it. We primed Schriebers car for a long time and I primed my car for a long time as well. It still took quite a bit of cold cranking for everything to get going. Don’t get discouraged by cranking but don’t just hold the key down for too long and heat up the starter. I prefer to go for 10-15 seconds at a time.
I used a fuel line Andrew developed for use with an EGR in place. As you have noticed I don’t have an EGR. I used the Darkside kit to remove it. This line does require a little modification. You need to use three washers to space the dipstick tube a little forward so it doesn’t contact the new fuel line. Don’t judge my locking washers, it’s the only option I had.
You also have to slightly push the AC line to clear the new 1 Micron filter you want to use.You can see the clearance that i got here.
Gone
WalkingDrunken is offline   Reply With Quote
Old December 10th, 2015, 18:03   #73
WalkingDrunken
TDI(s): NONE
Here are some finished pictures of the installation.
And here is a quick video of my car running.
https://goo.gl/photos/2YKinJAdYMBB8Tkt6
I also had my fluidampr and timing belt protector installed. It looks AWESOME! but I don’t really know the next time I’ll be able to see it.
Current engine state:
CR170, Malone stage 3.5, Rawtek turbo back, HP & LP EGR delete, Wagner Intercooler.
Impressions.
Sound: This pump definitely gives a different sound. I think it has a great little whine to it that I can hear when I’m driving. But I might be a little sensitive to clunks, clangs, and sounds. My girlfriend cannot hear a difference and we take my car everywhere.
Driving Impression Power:
I noticed a noticeable increase in power. I’m not going to guess on hp or tq increase. But I feel the increase in all RPM ranges and pedal position.
Driving Impression Mileage:
My mileage increased nicely. My “city” driving is too and from work which is 15 miles at 45mph on cruise control with a max of 6 stops. My city mileage has increased at least 5mpg. My highway driving is cruise control at 70MPH. This mileage has increased 3MPG. Disclaimer*These are short term results from this last week.
I feel like this pump increases efficiency over the old fuel pump. It takes less energy to turn and in turn rewards you with increased power, mileage, and reliability.
Andrew asked that I withhold pricing, pump model number, and pump source. Please contact Andrew with any ordering questions you might have. Message him on here or give him an e-mail at tdi2micron@yahoo.com
Gone
Old December 11th, 2015, 05:58   #74
WalkingDrunken
TDI(s): NONE
Another added note. Schriebers and myself both feel like our cars start faster with this fuel pump.
Usually it took about 3 or 4 cranks to start my car before and now it's only 1 or 2. Has anyone else noticed this?
Gone
Old December 11th, 2015, 07:36   #75
YukonLT
YukonLT's Avatar
Fuel Economy: Good
Yep, I noted it as well in my install thread. Congrats on the CP3 install
CP3 Pump Install Experiments.**Big Picts** 2micron VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 410 November 11th, 2016 07:38
CP3 Pump on a 09 JSW Paulinski VW MKV-A5 Golf/Jettas 15 September 10th, 2015 07:35
Another fuel pump failure thread dborja VW MKVI-A6 Jetta Sedan (~ 2011+) 83 May 21st, 2013 12:43
Fuel pump upgrade needed with turbo upgrade? (AHU) mk3tdi1996 TDI Power Enhancements 42 January 9th, 2011 15:15
Page generated in 0.18563 seconds with 11 queries
[Output: 148.55 Kb. compressed to 126.36 Kb. by saving 22.19 Kb. (14.94%)]
