Old September 22nd, 2015, 12:56   #46
Paulinski
Paulinski's Avatar
Stage 3.5++ here lol...
09 JSW - CR170 / Rawtek / JR Auto Performance-Buzzken Tune
Paulinski is offline   Reply With Quote
Old September 22nd, 2015, 15:05   #47
vwUMO
So on the CP3 front. Now that we'll have all that fuel, who wants to work on a fun project to get a bigger turbo in place to take advantage of it?! . I am thinking stock injectors are good for a longer pulse/quantity. Air becomes the next challenge (again)
1993 Corrado SLC boost-galore
2003 Jetta Wagon TDI 5MT 402k
2012 Jetta TDI 6MT 67k
2013 jetta TDI 6MT 41k
vwUMO is offline   Reply With Quote
Old September 22nd, 2015, 16:47   #48
ATR
ATR's Avatar
Gtb2566vk may be a good place to start turbo wise. You'll NEED a LSD and also strengthen up the transmission if you have a manual. And obviously a clutch upgrade.
Much more info here from someone who did a 2260 snail on his:
http://forums.tdiclub.com/showthread.php?t=367577
Check out the tray build up he did here:
http://forums.tdiclub.com/showpost.p...&postcount=133
Read from post 133 onwards for the tranny build up.
Drivers Wanted
-2011 Golf TDI 6MT = gone but not forgotten!
-2017 Golf GTI Sport 6MT
***Official maintenance schedule for your VW [PDFs inside]***
ATR is offline   Reply With Quote
Old September 22nd, 2015, 16:55   #49
turbobrick240
turbobrick240's Avatar
The gtb2260 will provide as much (or more) air as an unported head and stock injectors can handle. I personally wouldn't want to lose any more low end and response than what the 2260 provides.
Old September 22nd, 2015, 17:23   #50
ATR
ATR's Avatar
Good point on the low end torque. I'm guessing that's why hutchens went with the 2260.
Drivers Wanted
Old September 25th, 2015, 04:38   #51
schreibers
TDI(s): 2011 JSW TDI
Fuel Economy: Good
Any of you CP3 guys noticing changes in MPG? I drive approximately 75% hwy (65-70mph) and 25% city. Granted i'd go slower but my life is worth something
Calculated MPG is usually 36-38mpg (550-565mi at fill up). We have taken some long road trips and at those times i've gotten 48-52mpg. I'm sure the fact my car is raised on Tiggy+Towing springs doesn't help things in that regard.
Anyway, i've put 2 full tanks in since my install (1700 miles on new pump) and averaged 44.x almost 45mpg. Driving style and route have stayed the same. Still hot and humid as hell here in the Sunshine state.
schreibers is offline   Reply With Quote
Old September 25th, 2015, 05:11   #52
turbobrick240
I don't keep track of my fuel mileage very carefully, but I think I've picked up a couple mpg's since my cp3 install. On short relaxed trips (in warm weather) I can hit 50 mpg pretty routinely with my stage 3 setup. That said, I really enjoy the extra power and average more like 42 mpg overall. I wasn't expecting any mpg increases with my cp3, so it's an added bonus!
Old September 25th, 2015, 06:15   #53
YukonLT
Veteran Member - TDIClub Enthusiast
YukonLT's Avatar
Fuel Economy: Good
My MPG's have definitely gone up, and I'm loving that side effect! I'm stage III with an aggressive tune, and my mileage is the best it's ever been. Even with spirited driving each tank, I have been averaging 45mpg or better. Car is running beautifully
YukonLT is offline   Reply With Quote
Old September 25th, 2015, 20:09   #54
vwUMO
Same here. Manually calc'd (and SGII) 56.6 mpg to Boston and back yesterday... That included a few moments of spirited driving
Old November 5th, 2015, 17:44   #55
ticketed2much
ticketed2much's Avatar
TDI(s): 2010 JSW
Just curious, for the CRs with the CP3, are you using 2micron's contain flow and pure flow, or is there no need to? Looks like a worthwhile upgrade.
Originally Posted by elitegunslinger View Post
Our lord and savior 2micron who gave his only son CP3 to the world to absolve VW of their HPFP sins but could not save them from the hell which is the EPA.
ticketed2much is offline   Reply With Quote
Old November 5th, 2015, 18:04   #56
camboscams
Nope, luckily the CP3 has such a proven track record it is unnecessary for any containment.
However, some of us have chosen to utilize a 2 micron "prefilter" to have a more thoroughly cleaned fuel entering the HPFP.
camboscams is offline   Reply With Quote
Old November 9th, 2015, 13:47   #57
mr_y82
^this, except the prefilter IS the "contain flow" as far as I know... so you would just order it (but no "pure flow)... Andrew (2micron) could confirm if you were to purchase in the future... http://forums.tdiclub.com/showthread.php?t=375803
Malone Stage 2 Econo-Tune!;BuzzKen downpipe w/ cat!
2MicronTech Contain Flow and Pure flow Adapter FROSTHEATER
Appalachian Diesel Works, NC!(TRUSTED TDI MECHANICS)
Pre-tune: ~10k-70k mi = 40.5 mpgs; mpgs since tune_f_u_e_l_l_y_ ^
mr_y82 is offline   Reply With Quote
Old November 10th, 2015, 04:54   #58
WalkingDrunken
WalkingDrunken's Avatar
TDI(s): NONE
I helped install the CP3 on Schreibers and can confirm that the filter does not work as a contain flow. Andrew told us that it is not needed since the CP3 is so robust and there is no concern of failing like the oem pump has.
Just like camboscams mentioned the new filter is only a prefilter. Fuel goes into the OEM filter - to the 1 Micron Filter - to the CP3 Pump.
If you take a look back at the pictures, for testing Andrew did have it set up as a contain flow here (Posted 10/17/14)...http://forums.tdiclub.com/showthread...=367804&page=8
But then on Yukon's install, one of the very first/Beta, you can see the hose routing does not have it as contain flow(Posted 07/16/15)... https://forums.tdiclub.com/showthread.php?t=444018
Gone
Last edited by WalkingDrunken; November 10th, 2015 at 04:54. Reason: words are hard
WalkingDrunken is offline   Reply With Quote
Old November 10th, 2015, 08:58   #59
gloaming
gloaming's Avatar
Fuel Economy: 25-35mpg city and 45-55mpg highway.
Any word on if these are back in business again? I'd love to use my free money from VW to upgrade to cp3
gloaming is offline   Reply With Quote
Old November 10th, 2015, 09:28   #60
crazyrunner33
crazyrunner33's Avatar
From what I heard, they're on hold until this dieselgate is sorted out. I'd hold off on any modification until we know what's happening to our cars.
'06 Jetta DSG: GTB1749VC, PD150 injectors, Malone tune, and some other stuff and things
'97 Cummins: It looks stock, does that count?
crazyrunner33 is offline   Reply With Quote
CP3 Pump Install Experiments.**Big Picts** 2micron VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 410 November 11th, 2016 07:38
CP3 Pump on a 09 JSW Paulinski VW MKV-A5 Golf/Jettas 15 September 10th, 2015 07:35
Another fuel pump failure thread dborja VW MKVI-A6 Jetta Sedan (~ 2011+) 83 May 21st, 2013 12:43
Fuel pump upgrade needed with turbo upgrade? (AHU) mk3tdi1996 TDI Power Enhancements 42 January 9th, 2011 15:15
Page generated in 0.17277 seconds with 11 queries
[Output: 133.96 Kb. compressed to 112.01 Kb. by saving 21.95 Kb. (16.38%)]
