Old September 22nd, 2015, 05:03   #31
YukonLT
Veteran Member - TDIClub Enthusiast
YukonLT's Avatar
Fuel Economy: Good
Originally Posted by 2010JSWDSG View Post
Just finished the installation last weekend, so that makes me #10. Pretty straightforward install if you use the T10051 counter hold tool. The hardest part was getting the HP EGR valve out of the way.
Added to the list...congrats on the install!
YukonLT is offline   Reply With Quote
Old September 22nd, 2015, 11:21   #32
amstel78
amstel78's Avatar
Someone tell Andrew to clear his PM box!!!
-James
Gone but not forgotten: 2005 E46 M3 | 2006 Evo IX MR | 1985 W123 300D | 2012 Golf TDI
amstel78 is offline   Reply With Quote
Old September 22nd, 2015, 11:24   #33
Paulinski
Paulinski's Avatar
Best bet is to e-mail him.
09 JSW - CR170 / Rawtek / JR Auto Performance-Buzzken Tune
Paulinski is offline   Reply With Quote
Old September 22nd, 2015, 11:29   #34
amstel78
amstel78's Avatar
Good call. I just did.
-James
Old September 22nd, 2015, 11:32   #35
amstel78
amstel78's Avatar
So Yukon, what sort of MPG improvements do you see now there's less parasitic drag from the CP3?
-James
Old September 22nd, 2015, 11:40   #36
Paulinski
Paulinski's Avatar
I lost 1-2mpg but thats probably associated with the hot stage III tune I'm running.
Old September 22nd, 2015, 11:52   #37
amstel78
amstel78's Avatar
You running a larger turbo as well?
-James
Old September 22nd, 2015, 12:00   #38
Paulinski
Paulinski's Avatar
Cr170
Old September 22nd, 2015, 13:16   #39
YukonLT
YukonLT's Avatar
Fuel Economy: Good
I haven't been able to fully gauge that yet because I haven't been driving the car consistently in the same manner for long enough, but it's definitely improved.
Old September 22nd, 2015, 13:17   #40
YukonLT
YukonLT's Avatar
Fuel Economy: Good
I had my tune upgraded at TDIFest, and ever since then my mileage has been even better. No idea how it's even possible because Mark upped the fueling in the tune, but the numbers don't lie. I'm not complaining though
Old September 22nd, 2015, 13:22   #41
Paulinski
Paulinski's Avatar
Nice.
Mark updated my tune two weeks ago. Three revisions later and dozen logs Mark told my tuner that's as far as his comfortable pushing the turbo.
Old September 22nd, 2015, 13:29   #42
amstel78
amstel78's Avatar
Thanks. Good info guys.
-James
Old September 22nd, 2015, 13:32   #43
vwUMO
Im running the same tune as you without the cp3 and same here. Economy went up. Im also not driving it to the limit either. The suspension meeds upgrading now!
1993 Corrado SLC boost-galore
2003 Jetta Wagon TDI 5MT 402k
2012 Jetta TDI 6MT 67k
2013 jetta TDI 6MT 41k
vwUMO is offline   Reply With Quote
Old September 22nd, 2015, 13:39   #44
gloaming
gloaming's Avatar
Fuel Economy: 25-35mpg city and 45-55mpg highway.
Not to get too far off track here, but is there an update to the stage 3 tune or are you guys referring to the stage 3.5?
Not sure how much further I'm willing to push my tune at the moment. I get light flywheel shutter at decent throttle in 6th gear. The shudder isn't too bad though, I just pass in 5th gear (which is more fun anyway). Honestly I only get shudder when I purposely try to get it to see if that's actually what's happening or if its road noise/tire noise.
gloaming is offline   Reply With Quote
Old September 22nd, 2015, 13:45   #45
vwUMO
Yukon and I are at 3.5++ or something like that. Its real smooth. I also notice light chatter/shudder in 6th if it gets bogged down but 5th is the remedy. Other than that its now scary fast for what it is. I ordered a real egt probe but i would suspect that as long as i am not towing a car hauler up mt washington And use common sense all will be ok. With the higher egts, i have thought about making a cookbook for stage 3 enginebay recipes
CP3 Pump Install Experiments.**Big Picts** 2micron VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 410 November 11th, 2016 08:38
CP3 Pump on a 09 JSW Paulinski VW MKV-A5 Golf/Jettas 15 September 10th, 2015 08:35
Another fuel pump failure thread dborja VW MKVI-A6 Jetta Sedan (~ 2011+) 83 May 21st, 2013 13:43
Fuel pump upgrade needed with turbo upgrade? (AHU) mk3tdi1996 TDI Power Enhancements 42 January 9th, 2011 16:15
Page generated in 0.15755 seconds with 11 queries
[Output: 133.62 Kb. compressed to 111.58 Kb. by saving 22.04 Kb. (16.50%)]
