Old August 28th, 2017, 11:24   #256
skycrane
got the " fix" done with a Stage 2 and DSG running, with a CP3 upgrade, and baked on soot in tailpipe that Breakcleaner couldnt remove.
Andrew, do you make a filter that replaces the oem 20k crap one? so i dont have 2 filters that need to be replaced?
2012 Audi A3 TDI S-Line
Malone Stage 2, DSG Tune, CP3 pump upgrade, Emissions "fix", PolarFIS
skycrane is offline   Reply With Quote
Old August 28th, 2017, 12:47   #257
turbobrick240
turbobrick240's Avatar
He doesn't make filters. You don't really have to change the factory filter every 20k miles if you don't want to. I believe the interval for the same filter is more like 60k miles in Europe. And the cimtek filter can easily go 100k miles. It's just catching very minute amounts of very small particles.
Old August 28th, 2017, 13:19   #258
skycrane
sorry i meant the filter mounting thingey that you screw the filter into. besides, id rather change the cimtek filter once then the oem one 5 times by audi recomandations....
wasnt andrews kit was built to filter the HPFP when it grenades and shoots out all the metal shards into the rest of the fuel system.
what i was looking for was a cimtek filter and housing to compleatly replace the oem one, that filters down to 2 micron, and is good for over 100k miles. witch is about 18 months the way i drive or every 4 months by audi standards with the oem crap.
Old August 28th, 2017, 15:35   #259
turbobrick240
Andrews containflow filtering arrangement is plumbed differently than his cp3 polishing filter. Personally, I'd just change the factory filter every 40-60k miles if I drove that much. I've driven all over the country, and the filter and housing always look spotless when I do filter changes.
Old September 2nd, 2017, 14:00   #260
pkhoury
That guy with the goats
pkhoury's Avatar
Fuel Economy: CR - 36-41, PD - 39-48 (26-32 while towing)
Originally Posted by YukonLT View Post
Anyone that installs the CP3, post up so we can add to the list and hear about your upgrade!
Here are a couple links to the birth of this upgrade:
Andrew's initial testing and fitment
YukonLT's install and impressions
Looking forward to seeing more of these on the road!
It's not installed at this very minute, but add me to the list. Brian (alphaseinor) has the TB off (decided to change at 90K instead of 120K), and the CP3 will be installed before I leave.
Oh, and for the curious, the car is at maybe 2 dozen miles over 199K. TB was last changed at 110K (also done early). After having my TB take a crap on the Golf (BEW), I'll probably keep it around 90K change intervals, which is about every 4.5 years at the rate I drive.
**EDIT 09-03-17**
The car accelerates a lot quicker. The throttle feels very smooth, almost like a Nissan Leaf or other EV, or a luxury car. It felt scratchy before. Also, I noticed when I floor it, the car still rolls some coal, but it's not a smoke screen like it was prior to the upgrade. All in all, I'm very pleased.
2010 Jetta Sportwagen - Malone DSG tune, Malone Stage 3.5, CR170, buzzken 3" straight pipe(resonator deleted), PolarFIS, Panzer plate, front and rear fogs, Bosal towhitch, Bilstein B8/Neuspeed 28mm swaybar, 2micron CP3 upgrade kit
2004 Golf GLS 5MT -
Malone Stage 4, VNT17, DC Stage 2 clutch, buzzken 2.5" straight pipe, MFA cluster swap, dieselgeek Panzer plate and short shifter, Bosal towbar, Tekonsha P3 brake controller, Hopkins short-proof trailer light converter, darkside SMIC, intake manifold, and tip pipe, PD150 airbox
2005 Jetta Wagon GLS (mom's car) - Malone Stage 4, VNT17, MFA cluster swap, Panzer Plate, buzzken 2.5" straight pipe, darkside SMIC
2015 Golf Sportwagen TDI (mom's car) - stock for now...
Other diesels:
Ford 5900 tractor
Ford 3400 Industrial tractor
2016 Mahindra XTV (1L Kohler diesel)
pkhoury is offline   Reply With Quote
Old September 3rd, 2017, 13:30   #261
YukonLT
Veteran Member - TDIClub Enthusiast
YukonLT's Avatar
Fuel Economy: Good
**EDIT 09-03-17**
Added!
YukonLT is offline   Reply With Quote
Old September 3rd, 2017, 15:48   #262
pkhoury
pkhoury's Avatar
Added!
Sweet, thank you YukonLT. Now I just hope there's interest in the future for Mk7 owners (I know there's already a thread on it for the Mk7, but we all know it's a useless thread).
Some photos of the finished product, along with one of Brian's techs (a fellow BEW owner).
Oh, and this will be going up for sale on here. How quick it sells (if it sells) is anyone's guess.
I have yet to see how fuel economy is. I was in a hurry to get home after the install (we finished up around midnight), so I was doing between 79 and 90. Still got over 34mpg, though.
2004 Golf GLS 5MT -
Other diesels:
Ford 5900 tractor
Old September 6th, 2017, 06:19   #263
calimustang
Sweet! Congrats! I made 51 mpg at 80 mph with empty car. love it when she is empty.
2011 JSW TDI bought in Aug 13th 2010, retired with 281,535 miles, on process of buyback. will be sorely missed.
2015 Passat TDI with 22k miles, completely stock. Black exterior and black interior, will add tint and black out the wheels.
calimustang is offline   Reply With Quote
Old September 18th, 2017, 03:53   #264
pkhoury
pkhoury's Avatar
Well, of course you did; you're in Central FL. When I lived in Melbourne Beach a few years ago, it was cakewalk getting over 40mpg, even on 95. Not so much in Texas Hill Country!
2004 Golf GLS 5MT -
Other diesels:
Ford 5900 tractor
Old September 18th, 2017, 05:40   #265
adjat84th
adjat84th's Avatar
There are a few MK7 CP3s running around. I've detailed some of my install in my build thread and here as well. Very simple install with only one small adjustment to the pigtail connector going to the pump needing a trim. I wouldn't be surprised if Andrew has already sourced a different version that solves the issue though.
Sent from my Pixel using Tapatalk
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, DC stage 3 w/ SMF, Fluidampr
Old September 19th, 2017, 06:04   #266
calimustang
I wouldn't question that, been in TX and it's kinda hilly. There are some hills in FL, I do sometimes lose few MPGs from that. mostly on I-75 northbound... hate that road. from turnpike intersection into I-75 to Lake City, many hills. Now I no longer cover that area for work, good riddance.
Old September 28th, 2017, 05:00   #267
Smartcarper
Smartcarper's Avatar
TDI(s): VW T5 BiTdi
Hi Ecevryone
I am new to CP3 pumps but as an owner of a VW CFCA 2.0 common rail BiTdi engine I am aware that one of my engines biggest drawbacks regarding tuning is the poor volume capacity of the OEM fuel pump.
I would love to fit a high pressure high volume CP3 pump to my engine and have found many for sale from engines as small as 1700cc upto 6500 cc can anyone please point me in the right direction to source the correct pump ( donar car spec year and engine size) I fully understand I need an interface kit for correct installation. TIA
Smartcarper is offline   Reply With Quote
Old September 28th, 2017, 06:32   #268
2micron
TDI(s): None
Originally Posted by Smartcarper View Post
Hi Ecevryone
I can help you,
Email me,
tdi2micron@yahoo.ca
Thank you,
Andrew
2micron is offline   Reply With Quote
Old September 28th, 2017, 06:34   #269
ksing44
Good news for people with the CP3 that want the fix. I got the fix yesterday and the dealer didn't say anything about the CP3 pump and not having an auxiliary pump. The adviser said they looked hard to find anything wrong with my car, but they couldn't find anything and said my car was in great shape. They were also amazed how clean my car was, considering it has over 153,000 miles. I'm a neat nut.
Of course that doesn't settle worries about warranty after the fact, but at least I'll have my check for the fix.
2010 Golf TDI - Blue (BGM), 4-Dr, 6-M, Sunroof, Xenon, Dynaudio, Nav (RNS-510), Euro light switch, 9W7 BT, R Tinted LED Tail Lights, Monte Carlo 17" x 7.5" ET47 Wheels, 235/45/17 Tires, P3Cars Digital Interface, Sonniboy sunshades, CP3 HPFP!, The Fix - 9/27/17 @153,289 miles
Flickr slideshow
ksing44 is offline   Reply With Quote
Old September 28th, 2017, 18:36   #270
Mrrogers1
Fuel Economy: Never high enough but always trying for more.... (See signature)
That's great to hear!
Sent from my LG-LS993 using Tapatalk
Mrrogers1 is online now   Reply With Quote
CP3 Pump Install Experiments.**Big Picts** 2micron VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 410 November 11th, 2016 07:38
CP3 Pump on a 09 JSW Paulinski VW MKV-A5 Golf/Jettas 15 September 10th, 2015 07:35
Another fuel pump failure thread dborja VW MKVI-A6 Jetta Sedan (~ 2011+) 83 May 21st, 2013 12:43
Fuel pump upgrade needed with turbo upgrade? (AHU) mk3tdi1996 TDI Power Enhancements 42 January 9th, 2011 15:15
Page generated in 0.13353 seconds with 11 queries
[Output: 139.40 Kb. compressed to 117.39 Kb. by saving 22.01 Kb. (15.79%)]
