Old November 15th, 2014, 10:29   #16
corrado tdi
corrado tdi's Avatar
Fuel Economy: 43ish overall
The P2015 repair brackets are for sale here. The kits started shipping December 10th, 2014.
Jim Royston
www.dieselgeek.com
corrado tdi is offline   Reply With Quote
Old November 15th, 2014, 10:31   #17
ilyago
The joint should be forward (forward with respect to the car) when the car is idling, as seen in the picture below. If your flap is jammed, when the car is idling and the joint is in the rearward (in-car) position, prodding the linkage with a screwdriver wedged against the intake manifold casting should get the linkage to 'pop', it'll be freed, and will pivot forward. This was my case, the same as Ray Martinez'.
Unquote
When I first got the P2015 code, the ring was off the arm. I pushed it back, but it went back off as soon as I ran the engine.
Now the arm stays in the rearward position with the ring still on. I can push it with a screwdriver to make it flip to the forward position, but after I run the engine, the arm goes back to the rearward position and stays there.
Is my valve actuator motor broken or does the linkage just need lubing?
I will proceed with one of the other fixes once I can figure out how to get the arm to move back and forth.
-Ilya
2015 Jetta TDI S DSG
2015 Passat TDI SE manual
2010 JSW TDI 6-sp manual - SOLD in 2015
1998 Jetta TDI 5-sp manual - SOLD in 2010
ilyago is offline   Reply With Quote
Old November 15th, 2014, 11:02   #18
corrado tdi
Once the motor arm simply goes back too far the ecu just turns the motor off. The linkage arm doesn't have to get stuck to trip the code and render the motor inoperable. If we can limit how far back the arm can go to stock specs then it will not happen again.
Jim Royston
www.dieselgeek.com
Old November 15th, 2014, 20:21   #19
ilyago
Originally Posted by corrado tdi View Post
Not yet but soon. Trying to get them on several cars before we call the CNC program "good".
Do you think you will be selling it by 2014 year-end?
-Ilya
Old November 16th, 2014, 07:05   #20
corrado tdi
Yes, I do. The P2015 manifold fix is available now.
Jim Royston
www.dieselgeek.com
Old November 16th, 2014, 07:47   #21
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
I'll buy one.
2010 4D CWhite Golf TDI, 6 sp manual, Fluidampr, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits & timing belt cover, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is offline   Reply With Quote
Old November 21st, 2014, 18:34   #22
corrado tdi
Success! Runonbeer and I tested the repair kit yesterday on two different cars with four different manifolds and the part worked perfectly every time. I am changing a few things in the design to allow it to be more easily installed and will have production parts for sale on my site by very December 10th. (12-09-14: They are now for sale.)
We shot a YouTube video of a brand new manifold with the repair kit in place. The point of posting the video is to show what the butterflies do when you rev up the engine and when you shut it down. Enjoy!: http://youtu.be/cOyTGgi4sCU
Here is a YouTube video of installing the P2015 manifold fix.
Jim Royston
www.dieselgeek.com
Old November 25th, 2014, 13:38   #23
dustingebhardt
dustingebhardt's Avatar
Count me in when you get this up for sale. I have the same error code and I've tried making my own "stop" via the site mentioned by mr951 (https://sites.google.com/site/p2015fix/home). The error code went away, but it came back recently. I think I have the screw length set incorrectly. In any case, I'll buy the dieselgeek block when it is officially available.
2010 Jetta Sportwagen TDI: Fiesta Red, 6MT, ContiExtreme DW 225/50/16
dustingebhardt is offline   Reply With Quote
Old December 9th, 2014, 10:17   #24
dustingebhardt
Jim,
Any update on this? I'd love to give your part a chance on fixing my CEL.
Old December 9th, 2014, 10:39   #25
corrado tdi
The P2015 manifold fix is available now. They started shipping on 12/10/14.
Jim Royston
www.dieselgeek.com
Old December 9th, 2014, 11:33   #26
Chockomon
The P2015 manifold fix is available now. They will start shipping Wednesday the 10th.
I hope I never need this part but if I do, I'll be all over it!
I've been very happy with your products
Chockomon is offline   Reply With Quote
Old December 9th, 2014, 11:44   #27
corrado tdi
Keep in mind that the P2015 repair bracket is a preemptive fix, too. The earlier you limit the travel of the flapper motor, the lower the wear on the linkage. The factory stops are weak, ours are strong.
Jim Royston
www.dieselgeek.com
Old December 9th, 2014, 14:15   #28
VWYankee
My wife's JSW needs this as if 3 days ago. Great work as always!
'09 Manual TDI Sportwagen - Hers
4-Ringed Manual 4.2L Radio Flyer - Mine
VWYankee is offline   Reply With Quote
Old December 9th, 2014, 20:02   #29
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Just placed an order! THANKS.
Old December 10th, 2014, 04:52   #30
volks27
What are the symptoms (other than CEL) when this "arm" goes out ?
volks27 is offline   Reply With Quote
P2015 / VAG 008215 Intake Manifold Write-up and Replacement T-MILLS VW MKV-A5 Golf/Jettas 18 June 16th, 2016 03:25
2009 P2015 code - intake manifold and flap valves help DIY TerryE VW MKV-A5 Golf/Jettas 43 May 2nd, 2015 10:47
P2015 intake flap motor arm psdowner VW MKV-A5 Golf/Jettas 2 December 25th, 2013 12:49
Intake Manifold Flap Position Sensor Fault Code P2015 pawel VW MKV-A5 Golf/Jettas 0 August 11th, 2013 20:27
p2015 trouble code intake manifold runner sensor/switch????? mikertdi TDI 101 10 October 23rd, 2012 17:45
Page generated in 0.18834 seconds with 11 queries
[Output: 133.38 Kb. compressed to 110.74 Kb. by saving 22.63 Kb. (16.97%)]
