Old December 6th, 2015, 05:31   #46
pknopp
I removed my filter (checked for flakes, there was none) put the new one in, buttoned it all back up and started it. Let it run for a minute and drove off. No drama.
pknopp is offline   Reply With Quote
Old December 6th, 2015, 11:37   #47
StevesTDI
StevesTDI's Avatar
Fuel Economy: Better than hybrids
I'll be doing mine today old school. I advised/hinted to the wife I'd love to have a VCDS for xmas. Hope I was on the good list. :-)
StevesTDI is offline   Reply With Quote
Old December 6th, 2015, 12:38   #48
JSWTDI09
JSWTDI09's Avatar
Originally Posted by Racerman27410 View Post
I purchased VCDS ....snip...
Since i have it... i use it.
Everybody has to steer their own boat.
There are several threads here (and elsewhere) debating this topic and I have read most of them. When it comes to fuel filter changing on a CR engine, people seem to fall into two simple categories. Those who have VCDS (or access to it) and those who don't. Those who have VCDS would not think of changing fuel filters without priming the fuel system and those without access to VCDS (or another similar tool) rationalize their method by the logic of "well, it hasn't killed my HPFP yet" - and they might be right, we really don't know. After reading hundreds of posts about this subject - this seems to be what it really boils down to. As stated above: "Everybody has to steer their own boat".
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old December 6th, 2015, 13:13   #49
turbobrick240
turbobrick240's Avatar
And there are probably at least several with vcds who prime manually. Changing the fuel filter isn't opening the fuel system in the sense that some seem to think. Much like changing the oil filter isn't opening up the engine.
Old December 6th, 2015, 13:31   #50
turbobrick240
I think it comes down to type A and type B personality. Type A will see a torque spec for lug bolts, and out comes the torque wrench. Type b will think, gee I'm hungry, and out comes the four-way.
Old December 7th, 2015, 01:01   #51
StevesTDI
StevesTDI's Avatar
Well it's done and no hitches except for a little deisel that pushed out of the canister and caught by paper towels. Started right up no problem. I again hinted to the wife about my xmas wish.
Old August 17th, 2017, 06:54   #52
Jeffro420
Just wanted to bump this with an update - I changed my fuel filter the other day without the VAGcom software (2010 Jetta TDI late one-hole filter). I used a bungie cord to hold the fuel filter housing cap up (to reduce air into the tubes), filled the fuel filter housing up with diesel, put plenty of paper towels around when I squeezed the housing down, and it started up just fine! Didn't have trouble turning over at all.
Jeffro420 is offline   Reply With Quote
Old September 17th, 2017, 15:53   #53
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
You must have looked it up on the web like I did.
Used bungee cord too. Gently pulled up on the filter and let the diesel run out. Immediately threw it into a plastic shopping bag. Checked the bottom of the filter housing which was clean as a whistle. Next gently lower the new filter into the housing to let it soak up any diesel. Then filled it to the top with PowerService Silver. Closed it up and engine started right away.
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Jetta_Pilot is offline   Reply With Quote
Fuel Filter Change @ 40K...filter = very clean vs original. UberVW_TDI VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 September 5th, 2011 19:10
fuel filter and air filter change out TDIEB VW MKIV-A4 TDIs (VE and PD) 12 March 10th, 2010 18:48
No Fuel after fuel filter change and TB change npdimonte TDI 101 9 March 22nd, 2009 06:51
Fuel Pump failure after fuel filter change gmichaud VW MKIV-A4 TDIs (VE and PD) 11 November 10th, 2008 10:29
Leak at Fuel Filter After Filter Change NadaGasser VW MKIV-A4 TDIs (VE and PD) 8 May 1st, 2008 19:31
Page generated in 0.16320 seconds with 11 queries
[Output: 88.39 Kb. compressed to 76.51 Kb. by saving 11.88 Kb. (13.44%)]
