Old June 9th, 2010, 14:17   #31
sjjaskow
sjjaskow's Avatar
Dweisel, I think that we should add on just one more 'known' quantity to your list, how soon you can have an HPFP blow up. Has anyone read or remembered one that has happened with less than 1k miles on the vehicle? To me if such an early failure exists it would definitely by manufacturer error.
Where are these pumps made? Is there more than one assembly plant? If all the affected pumps were assembled from date x to date y at plant z, that should tell us something.
Thanks,
Steven.
Lola the 2010 Golf 6M--4Door *Candy White*
Mine since 5 June 2010
sjjaskow is offline   Reply With Quote
Old June 9th, 2010, 14:29   #32
ziggy55
Also we should try to get a hold of a new pump and test the hardness.
I would imagine that for both cam and piston roller to wear they must be made of same hardness or does it look like one is sacrificed before the other.
ziggy55 is offline   Reply With Quote
Old June 9th, 2010, 15:12   #33
ziggy55
maybe we should setup a fund so we can buy a new pump for Oilhammer to work on/analyze/test.
Old June 9th, 2010, 15:41   #34
DoctorDawg
DoctorDawg's Avatar
Originally Posted by dweisel
What we now know about hpfp failures
1) All 09/2010 are subject to possible hpfp failure
For the sake of precision I feel the need to point out that we don't actually "know" this, except in the same sense in which we know, for instance, that everyone on earth is "subject to possible" fragmentation grenade attack by a meth-crazed donkey on roller skates....or in the sense that all diesel engine owners everywhere are subject to possible hpfp failure.
The meaningful question concerns the odds, and we don't yet know the odds. While I increasingly share the opinion that the odds are higher than they should be (i.e., higher than for previous version TDIs), it remains the case that an opinion is not knowledge.
Just trying to maintain the always-useful distinction between what we think and what we know, since the blurring of this distinction is the source of most of the world's problems.
2009 Jetta TDI (Loyal Edition, Campi White, DSG, #1470, built 5/08): 56K miles and zero problems 1/16/2011.
WeatherTech deflectors, Dieselgeek skid plate (both A+)
My other diesel gets 120 MPG (minutes per gallon): Kubota 2630 w/ FEL
My other other diesel I don't even want to talk about (1995 Dodge Ram 2500 Cummins 4x4)
DoctorDawg is offline   Reply With Quote
Old June 9th, 2010, 16:14   #35
cevans
TDI Parts Ninja Vendor
cevans's Avatar
Armchair Expert Opinion:
Lubricity. The roller and cam lobe are not lubricated enough and wear through each other. And/or the lubrication on the roller isn't sufficient to allow it to roll at the appropriate speed.
End expert opinion.
IDParts.com - IDParts.com Vendor Thread - The IDParts Blog - IDParts YouTube Channel
Current: '14 Ram 1500 Eco, '11 R350 BT, '06 E320 CDI // Past: '13 NMS, '10 JSW, '10 Jetta Sedan, '07 R320 CDI, '03 Wagon, '00 Golf 2-Dr, '00 NB (Yellow :-)
Stop Hunting for Torque Specs - Get A Free IDParts Torque Spec Poster Today!
cevans is offline   Reply With Quote
Old June 9th, 2010, 16:25   #36
Ski in NC
Fuel Economy: 48-52 typical
If the cam and roller were lubricated with crankcase oil instead of fuel, there would likely be no problem.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old June 9th, 2010, 17:01   #37
Growler
Got Soot Vendor
Growler's Avatar
is the area where the fuel comes in contact with teh roller and cam open to any of the high pressure system? or is it a seperate circuit in the return path that lubricates the cam & roller?
if so, what about bypassing that area with the return fuel, and rerouting an oil line up there instead?
just talking outta my @$$ here but its a thought.
~Aaron~
TDI Service RE OPENED!
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old June 9th, 2010, 17:19   #38
DoctorDawg
DoctorDawg's Avatar
So we have (at least) three hypotheses (which may not be mutually exclusive):
1. Bad engineering, which can permit the roller to turn with respect to the cam under some (currently unknown, but presumably rare) conditions.
2. Bad metallurgy, employing steel grades which can suffer too much wear too fast under the lubricity/cleanliness conditions of real-world U.S.-of-A. diesel fuel.
3. Or it could even be that #2 can lead to #1...too much wear leads to slop in the cam/roller train which can enable the roller to rotate w/r/t the cam; if the metal particles don't get you first then sooner or later your HPFP will catastrophically grenade.
#1 would, I think, probably result in instantaneous catastrophic grenading of the HPFP, leaving clear signs inside that all hell had suddenly broken loose, whereas #2 will slowly but surely accumulate minute metal particles in the fuel system which will sooner or later take their toll on the engine's ability to run, leaving inside the HPFP only a wear signature such as we see in oilhammer's photos, but no evidence of catastrophic failure.
If Hypotheses #2 or 3 are correct, use of a lubricity enhancer is definitely called for. So given what we (don't) know today, I would argue that use of a lubricity additive (or B5) is a wise thing to do, with or without a recommendation from VW. Unfortunately, if Hypothesis #1 is correct then there's not much we can do; its on VW and Bosch to cowboy up and make it right, either before an inevitably successful class action law suit or after.
One thing I'll say here is that I just can't believe that this new HPFP design wasn't extensively tested with real-world fuel, so its just hard to figger how the heck they didn't see this coming. However I am reminded of the frequency with which I buy a bunch of high-grade bolts and find after I've installed them outdoors that one or two are rusted all to hell while the rest still look shiny new, from which observation I have concluded that the supply chain for various high-grade steels is perhaps thoroughly 'contaminated' with low-grade knock-off steel from A Country Which Need Not Be Named Here (ACWNNBNH). So maybe (just a wild-eyed conspiracy theory) Bosch spec'd and tested the correct steel, and it was all good, but now in production they unknowingly end up making some fraction of pumps from cr@ppy knock-off ACWNNBNHese steel? Low probability, I'll admit, but I'm just so puzzled by the question "How on earth did this get past a company like Bosch?" I mean, this ain't hardly their first rodeo.
Old June 9th, 2010, 18:17   #39
saucer
Coming from the MKV FSI community, this is shockingly familiar
Anyone involved in FSI forums should know by now that it's crucial to check the thimble style cam follower every 10k miles or so. The funny thing is, everyone brainstorming the problems with our HPFPs believe a roller would be the solution!
Here's an example of what a busted follower looks like on the FSI. Note the hollowed-thimble follower (lower right) and the disintegration of the plunger/spring on the HPFP (center):
And the ultimate effect on the cam lobes:
There are hundreds of threads regarding this issue of golfmkv, myfastgti and the vortex. People have been mailing their shredded followers to VWoA, threatening class action lawsuits, and raising just as much of a stink for over three years now but afaik, VW hasn't even released a TSB.
The issues don't seem to be quite as severe when the follower is finally eaten through as with the TDI though. People have even continued to drive for thousands of miles with little more than fuel cuts and rough idling. Still a mess to fix... I've seen numbers of $6k or more for replacing the cam shaft, pump, etc.
I pulled mine at 35k and the DLC was completely gone with a bit of scoring on the metal beneath, looking a just a bit worse than the one on the left:
The different harnesses of metals did play a role in helping the scenario - but not fixing it. If I remember correctly, 06 and some 07s came with a cam lobe that was too hard (or too soft?) that created a frictional incompatibility. This is also a double edged sword; after the follower is chewed through, the cam lobe is damaged from grinding on the new bits of shrapnel and the plunger from the HPFP. Then once the plunger is eaten through.... boom.
The only "good" thing about the FSI scenario, is this it being a 15 minute/$50 fix. Doens't look so easy or preventable with the TDI. FSI guys have been testing every oil and additive under the sun, and no one has nailed a firm conclusion on lubrication there either.
After seeing this issue in other VWs... instant facepalm.
saucer is offline   Reply With Quote
Old June 9th, 2010, 19:00   #40
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Guys, please keep the thread relevant. I started this thread because there are plenty of other threads about the odds of this happening or not happening, and as a VW specialist, I feel for the FSI owners, but again, that is not the scope nor purpose of this thread.
Right now I would love to get my hands on a new HPFP and take it apart. I think that the piston roller is too small, and can go off square in the bore. But in order to make it larger, they would have to make the piston cup longer, which would mean the entire upper part of the pump body would need to be extended some. And then it needs to be made so that it cannot turn in its bore.
I looked at my specimen today with a high powered magnifying glass, and it clearly looks like it did indeed spin wonky in the bore and wore some bad spots in the roller in short order.
There is also a lot of scoring on the piston itself.
oilhammer
www.cardocautomotive.com
Old June 9th, 2010, 19:03   #41
Derrel H Green
Derrel H Green's Avatar
Fuel Economy: Check my Fuelly
Thumbs down Just Because it's Bosch
doesn't mean it is the best or is as clean as it should be as you might believe!
Case in point:
Back in 1979, both my now deceased friend and I had new "L" model VW four door diesels, and
we went together halves on a set of brand new injectors from VW. These were brand new,
not rebuilt, and still sealed in their respective boxes, unopened. $30 each back then.
When he opened each injector body to reset the spring tensions to 2000 pounds firing pressures for
my hotrod turboed 1457 cc engine, he found rust in each one! Rust in brand new Bosch injectors.
Don't get the idea because it's Bosch that it is clean and precision built. It just is not so.
D
2010 JSW. Reflex Silver/Titan Interior. A TDI with DSG.
Dynoed 132 HP, 230 ft/lb torque at the wheels.
Traded the VW for a Mercedes Benz W-211 E-320 CDI 12-17-2011.
Dynoed 12-01-12 211 HP, 386 ft/lb torque at the wheels.
View my MBZ E-320 CDI Fuelly: http://www.fuelly.com/driver/derrelhgreen/E320
Compare our previous VW TDI JSW DSG Fuelly : http://www.fuelly.com/driver/derrelhgreen/Jetta
Derrel H Green is offline   Reply With Quote
Old June 9th, 2010, 23:13   #42
martytdi
Would some biodiesel make the fuel a little more slick?
2010 JSW with DSG
martytdi is offline   Reply With Quote
Old June 9th, 2010, 23:41   #43
Derrel H Green
Thumbs up Of Course
2010 JSW with DSG
it would Marty. That's why I heard that the editor of PM mazagine was told by VW to take the test
-car he was driving down to Playa del Rey (a Yacht type harbor) and get some biodiesel and
add that to the mix AFTER that car had the works done on it when it's HPFP went South!
Let me put it this way: Biodiesel or any additive that does not harm the DPF
certainly will not hurt anything provide you do not go overboard.
D
Old June 9th, 2010, 23:41   #44
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: No data yet.
Originally Posted by D-Cell Mekaneck
Maybe you could add a chip detector in the return fuel line?
Magnets on your fuel lines are starting to sound pretty good.
nicklockard is offline   Reply With Quote
Old June 10th, 2010, 06:38   #45
saucer
Sorry I got carried away with the FSI info - I thought some might find it interesting
Here's a huge thread on vortex about the FSI roller solution... maybe someone could get some ideas or PM H2Sport to see how they plan on keeping the roller straight.
As I mentioned though, the FSI HPFP is very easy to access and inspect. Is that not the case here?
I'll be picking up a new TDI in a week or so am getting nervous about this mysterious roller.
Page generated in 0.17654 seconds with 10 queries
[Output: 137.60 Kb. compressed to 115.40 Kb. by saving 22.20 Kb. (16.13%)]
